d16z6 head mixup
Old Dec 16, 2005 | 10:09 PM
Mach69's Avatar
Default d16z6 head mixup
I tried asking this in the '92-'00 civic eg/ek forum, no firm response, and I also tried in the crx/civic pre 92 forum to no avail as well. Anyway...
Block: '93 Z6 Head: '94 Z6
I have quite a dilema. I took apart my vtec assembly on the head. I took off the solenoid completely. I look down at the vtec housing (the thing the vtec solenoid bolts on to) and the piston in the housing has a hole in it. I also knew I had a spare one (housing from a '93 head), so I look at that and realize the piston in that housing is different. Here is what I mean:
See the hole on one of pistons and the other piston does not have a hole in it? Is the vtec solenoid the same for both housing models? And, does anyone have any idea which housing/piston is correct for my year engine?
I do not know which housing is from '94 or '93, but the vtec solenoid is from '93
I looked at the head and this is what it says just above the exhaust manifold: P08-5; then there are a few circles and this is exactly what it shows in the four circles:
<U>1:</U> 9\4
<U>2:</U> /6
<U>3:</U> 2\8
<U>4:</U> 0/6
Would the '93 block and the vtec assembly match the head?
Also, I have no codes, and I am damn sure oil pressure is the reason my vtec is not engaging.
Old Dec 17, 2005 | 10:15 PM
Mach69's Avatar
Default Re: d16z6 head mixup (Mach69)
Someone on honda-tech has to know this.
Old Dec 18, 2005 | 05:01 AM
solfly's Avatar
all vtec solenoids share the same part number
Old Dec 18, 2005 | 09:15 AM
Mach69's Avatar
Default Re: d16z6 head mixup (solfly)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solfly &raquo;</TD></TR><TR><TD CLASS="quote">all vtec solenoids share the same part number</TD></TR></TABLE>
Yes, I realize that, but its not the vtec solenoid that isn't working.
Its the vtec housing that I have the problem with. I believe the hole in piston there is causing me to lose oil pressure thus not allowing vtec to engage.
EDIT: i want to confirm its the vtec housing so I am not doing work for no reason.
Champs32
Sep 18, 2008 06:45 AM
1.3mazda
Feb 27, 2008 07:41 AM
civic2nr9177
Mar 22, 2004 07:43 AM
