h22 swap into 91 accord....? about tranmission mount
i have a h22 motor that doesn't come with tranmission bracket...so i use my old 91 accord bracket and mount to put on h22 tranny. It not fit and it doesn't line up correctly...
so which bracket and mount do i get???
yeah if its auto, use your stock mounts. mine fits fine with no problems. if you are going h22 or h23 5spd use the 5th gen accord or 4th prelude tranny mount. otherwise get a 90-93 accord 5spd mount that you have to reweld. to make the engine level (going the 5th gen accord and 4th gen prelude route) either redrill new hole on tranny or use 2 3/8 washers on the drivers side mount. here is the cb7 link for those who may think i am b-sing you all. note this does not work using the f22 tranny
http://www.cb7tuner.com/vbb/showthread.php?t=34274. very informative. i am going with the 5th gen accord mount and use the washers trick.
JBk24crx
Apr 16, 2005 01:35 PM
... i ll look up and see what happen
