Tranny Oil Question.
Old Dec 16, 2005 | 04:38 PM
frog169's Avatar
Default Tranny Oil Question.
I have a 92 civic, a place said i should use 10-30w motor oil? i got it changed at some shop they said they were gonna put gear oil but they ended up putting 5-30 i think. so was wondering would it be bad to put gear oil in it?
Old Dec 16, 2005 | 04:40 PM
Crx Jimmy's Avatar
Default Re: Tranny Oil Question. (frog169)
you want to use genuine honda MTF, .
Old Dec 16, 2005 | 04:41 PM
typeoneeg6's Avatar
Default Re: Tranny Oil Question. (Crx Jimmy)
honda mtf is the best. but the haynes manual says you can use 10w40.
Old Dec 16, 2005 | 07:24 PM
frog169's Avatar
what would u say about a leak.. i guess the prev owner put in nonslip or what ever and i guess when they sealed it, they didnt do a good job so it has a little leak, u think the thicker genuwine gear oil will make it leak less then 5w30 or 10w40
Old Dec 16, 2005 | 08:58 PM
snatch's Avatar
If it has a leak, you need to fix the leak not worry so much about which fluid is going to make the leak better.
The Honda MTF will be best for the performance of the tranny as far as lubricating the gears/synchros, etc.
Old Dec 16, 2005 | 09:35 PM
For_Sale's Avatar
"The Honda MTF will be best for the performance of the tranny as far as lubricating the gears/synchros, etc. "
Honda Manual Transmission Fluid is always good, but there are a couple others that are superior.
"GM Synchromesh" is great. Can be bought at GM dealership parts store. Very expensive. Around 30 bucks a bottle.
It WILL cure light to medium grinds. Search the forums for "GM Synchromesh"
Old Dec 16, 2005 | 10:01 PM
deadlock32's Avatar
Default Re: Tranny Oil Question. (junkyard_turbO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by junkyard_turbO &raquo;</TD></TR><TR><TD CLASS="quote">"The Honda MTF will be best for the performance of the tranny as far as lubricating the gears/synchros, etc. "
It WILL cure light to medium grinds. Search the forums for "GM Synchromesh"</TD></TR></TABLE>
I beg to differ.
https://honda-tech.com/zerothread?id=1465832
Old Dec 16, 2005 | 11:11 PM
frog169's Avatar
Default Re: Tranny Oil Question. (******)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ****** &raquo;</TD></TR><TR><TD CLASS="quote">If it has a leak, you need to fix the leak not worry so much about which fluid is going to make the leak better.
The Honda MTF will be best for the performance of the tranny as far as lubricating the gears/synchros, etc.</TD></TR></TABLE>
I have to agree, but when there going to charge $550 bucks to pull the tranny and fix it thats kinda 2 high for my pockets atm.
Old Dec 16, 2005 | 11:52 PM
crxnj's Avatar
I use penzoil Syncromesh..Its only $5 a qt and almost the same as gm syncromesh..Who do you think makes GM syncromesh? Pennzoil does
Old Dec 16, 2005 | 11:56 PM
JDM-EJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">you want to use genuine honda MTF, .</TD></TR></TABLE>
Yup.
95_Civic_4dr
Sep 16, 2009 10:05 AM
mattm868
May 27, 2007 03:21 PM
boosted94teggy
Oct 27, 2005 12:42 PM
ptownsintegra
Sep 14, 2005 07:43 PM
galaxycivic
Jun 10, 2001 04:36 PM
