Looking for a 60mm to 63mm (2.5") expander section
Old Dec 16, 2005 | 03:58 PM
Boilermaker1's Avatar
Default Looking for a 60mm to 63mm (2.5") expander section
My new turbo came and it's got a 60mm inlet flange. Problem is nothing else is really available in 60mm (filters, etc...) So I've been looking for an adapter section that I can use to just bump it up to 2.5 (I'll run a few inches of 60mm pipe, expand it to 2.5, then continue on to the filter), but I can't find what I'm looking for. I'm guessing due to it being such a small diameter bump. Anyone know where I can find one? It would be greatly appreciated.
Old Jan 17, 2007 | 11:19 AM
HiProfile's Avatar
Default Re: Looking for a 60mm to 63mm (2.5") expander section (Boilermaker1)
edit - posted to a wrong post. I really hate having 15 windows open
Old Jan 17, 2007 | 01:12 PM
CivicVX94's Avatar
just use a silicone coupler and a t clamp, if properly tightened i can't imagen it not sealing due to 3mm
Old Jan 18, 2007 | 06:43 PM
sharkytm's Avatar
Default Re: Looking for a 60mm to 63mm (CivicVX94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicVX94 &raquo;</TD></TR><TR><TD CLASS="quote">just use a silicone coupler and a t clamp, if properly tightened i can't imagen it not sealing due to 3mm </TD></TR></TABLE>
If you are worried, a thin bead of silicone around the outside of the coupler will ensure a seal.
Old Jan 18, 2007 | 08:56 PM
Holy old thread....Problem long since solved. I had someone weld a 2.5" pipe over the 2 3/8" turbo flange, then blended the 2 together so inside its a reducer.
Old Jan 19, 2007 | 06:58 AM
CivicVX94's Avatar
Default Re: (Boilermaker1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boilermaker1 &raquo;</TD></TR><TR><TD CLASS="quote">Holy old thread....Problem long since solved. I had someone weld a 2.5" pipe over the 2 3/8" turbo flange, then blended the 2 together so inside its a reducer.</TD></TR></TABLE>
o **** i didn't even realize that lol i saw it at hte top of the forum and replied
Old Jan 21, 2007 | 10:48 AM
bigTom's Avatar
60 to 63mm expander? Why dont you just use a 2.5" tube with a 2.5" siliccone respectively. Does a 3mm reducer even exist?!
RCautoworks
Welding / Fabrication
May 4, 2008 05:23 PM
TwinT66
Feb 21, 2008 07:38 AM
mrbsponge
Jul 2, 2007 05:18 PM
juicedse
13
Jan 19, 2005 05:23 PM
tunes12
Jan 15, 2004 12:49 PM
