Suspension & Brakes Theory, alignment, spring rates....
Integra brakes on an EH, Camber??
Old Dec 16, 2005 | 03:04 PM
UrbanEh's Avatar
Default Integra brakes on an EH, Camber??
I just installed integra brakes on all four corners of my 93 Hatch. I replaced the swingarms in the rears and the front hub assembly in the fronts. My question is for people that have done this swap, did you notice an increase in camber? Its a pretty big difference from what it used to be, I am getting a camber kit to fix it, just wanted to know if anyone else has had this problem.
Old Dec 16, 2005 | 08:02 PM
_BEN_'s Avatar
Default Re: Integra brakes on an EH, Camber?? (UrbanEh)
I have done this and did not notice any difference. I did a complete suspension swap from a DC. My bushings were shot on my '92 Si.
What year integra did you ge the brakes from?
Just to clarify:
You only changed the hubs up front and not the upper/lower controll arms?
Old Dec 17, 2005 | 09:13 AM
UrbanEh's Avatar
Default Re: Integra brakes on an EH, Camber?? (_BEN_)
Its off a 95 integra special edition, Yeah your correct only the hub assembly not the upper or lower control arm. Will those swap over onto the EG??? HMM never thought of that.
Old Dec 17, 2005 | 11:29 AM
gsrious's Avatar
change the arms too...
Old Feb 1, 2007 | 03:34 AM
eastbay92cx's Avatar
Default Re: (gsrious)
I also replaced the brakes on my eg with integra brakes. I took the upper arms and knuckles from a 97 gsr, and used the stock lower control arms from the civic. I think this may be where the problem lies. Even with a ~2" drop, the car has positive camber in the front. I think you may need to use integra lca's also.
Resurrected this thread, but I don't see any other info. Anyone?
fastblacks2k
Oct 7, 2007 09:40 PM
Kool305
Feb 1, 2007 03:35 AM
UrbanEh
2point3h22lude
Sep 13, 2005 02:32 PM
ihateslowhondas
Oct 18, 2004 06:46 PM
