d16 compression
Old Dec 16, 2005 | 02:13 PM
silverboost's Avatar
Default d16 compression
im gonna be compression testing soon, wat should my readings be????
Old Dec 16, 2005 | 02:20 PM
SOHC4life 96's Avatar
Default Re: d16 compression (silverboost)
What d16 is it?
Old Dec 16, 2005 | 02:55 PM
nub's Avatar
nub
Default Re: d16 compression (SOHC4life 96)
there are no set numbers you should see its all a matter of miles on the odometer and maintenance over time. id say in the 160-180 range, its more important that the numbers for all cylinders are within 10% of each other
Old Dec 16, 2005 | 02:59 PM
Farmer Brown's Avatar
Default Re: d16 compression (nub)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nub &raquo;</TD></TR><TR><TD CLASS="quote">there are no set numbers you should see its all a matter of miles on the odometer and maintenance over time. id say in the 160-180 range, its more important that the numbers for all cylinders are within 10% of each other</TD></TR></TABLE>
jdmitrna
Jul 5, 2008 04:48 PM
Mr.OB*GYN_Rhett
Aug 17, 2006 10:54 PM
XstouterX
Feb 26, 2006 03:06 PM
iTzKeviN
Oct 14, 2005 09:01 PM
peel17
May 29, 2005 01:19 AM
