Strut sits to high
Old Dec 16, 2005 | 01:41 PM
C2daIzZle's Avatar
Default Strut sits to high
Okay, I changed out the struts on my car around a month ago, however I put my springs back on my stock struts, when I put them on, the driverside strut sat up higher than the passenger. Well, now I replace them with AGX's, same problem. Only difference now, theyre gas struts so the strut bounces around when I hit bumps, must fix ASAP I have no idea whats wrong. the ring that goes under the locking nut does not sit flush on the bottom of the strut barrel as it does on the other struts, any idea? I have a drive to IL from NC Tuesday.. I need to fix this ;/ Thanks
The problem:
Modified by C2daIzZle at 1:51 PM 12/17/2005
Old Dec 16, 2005 | 03:45 PM
C2daIzZle's Avatar
anyone?
Old Dec 16, 2005 | 03:54 PM
Civicse's Avatar
Default Re: (C2daIzZle)
try loosening all the bolts holding the strut to the control arm and damper fork, and jack up the control arm till the car lifts off the jack stands, sounds like it might not have seated properly? worth a shot anyway
Old Dec 17, 2005 | 09:08 AM
C2daIzZle's Avatar
anyone else?
Old Dec 17, 2005 | 09:52 AM
C2daIzZle's Avatar
updated with picture, also the nut seems to keep loosening itself up, im assuming from being banged againist the chasis when bumps are hit. also, i can pull the strut to the middle of the circle the strut sits in, but i cannot get it to sit flush to the bottom of the chasis.
Old Dec 17, 2005 | 09:54 AM
Archidictus's Avatar
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C2daIzZle &raquo;</TD></TR><TR><TD CLASS="quote">updated with picture, also the nut seems to keep loosening itself up, im assuming from being banged againist the chasis when bumps are hit. also, i can pull the strut to the middle of the circle the strut sits in, but i cannot get it to sit flush to the bottom of the chasis.</TD></TR></TABLE>
It's not helping that you put the strut together completely wrong. Can't you tell that from simply looking at the picture? Just ******* wow, dude. If you can't install suspension correctly on your own, take it somewhere that can so you aren't a rolling accident waiting to happen.
Old Dec 17, 2005 | 12:06 PM
CR-V-tech's Avatar
Default Re: (Archidictus)
I agree with this guy, there isn't even a bushing under that washer retainer, if u can't put it back together right u don't need to be working on it!
Old Dec 17, 2005 | 12:12 PM
buy my boosted ek's Avatar
Default Re: (CR-V-tech)
u didn't put it back together right. you're missing the washer and or bumpstop.
Old Dec 17, 2005 | 12:16 PM
ironcheftony's Avatar
missing the top hat bushings for sure, and possible the washer in the middle of the strut
Old Dec 17, 2005 | 12:30 PM
igo4bmx's Avatar
wow... just wow
Old Dec 17, 2005 | 12:33 PM
sohcvtec1995's Avatar
Default Re: (igo4bmx)
wow i havent posted in such a long time and i come back to see this... amazing.
Old Dec 17, 2005 | 02:44 PM
B-SerioUs EGg's Avatar
B A N N E D
Default Re: (sohcvtec1995)
bushing
mesmittyme
Honda Civic (2001 - 2005)
Aug 26, 2015 08:42 PM
rollinhonda3
Sep 11, 2010 11:36 AM
Terabass
Dec 20, 2007 10:47 PM
Hyb
Suspension & Brakes
Jan 15, 2005 09:07 AM
