88-95 Civic lower control arm bushing size?
I am looking for the diameter size of the bushing on the rear lower control arm. That is the outside diameter size of the metal part of the bushing. I think the two outsides are the same size and the middle is different. If anyone has one laying around and has a micrometer could you check it out for me.
thanks, I saw your post in the archives back in May, but I was looking for the exact measurements so I can use something to press them out. Also in the post you had measurements like .75" X 1.30". Is the .75" the diameter across (through where the bolt goes through) and 1.30" the outside diameter of the metal circle? I'll just wait till you post the measurements, thanks
do oyu have a link to that thread?
i suppose this one.
https://honda-tech.com/zerothread?id=1244856
i measured the ID and OD of the energy suspensions bushing. not the stock one.
i have a stock one at home laying around ill measure later.
Modified by Tyson at 3:19 PM 12/16/2005
i suppose this one.
Ok awesome, just make sure its the size of the outside diameter of the metal part of the bushing, thanks again
theYBLEGAL
Suspension & Brakes
11
Mar 22, 2015 09:12 PM
spankey167
Apr 12, 2005 05:36 AM
StyLz
Jan 29, 2005 11:51 PM
