Honda S2000 Honda S2000
S2K ecu/cluster question true or false
Old Dec 16, 2005 | 11:14 AM
s2k drifter's Avatar
Default S2K ecu/cluster question true or false
Hi, just wanted to know if the s2k ecu is what gives the milleage reading to the cluster or is the mileage recorded on the cluster inself.
Old Dec 16, 2005 | 11:21 AM
Francesco's Avatar
Default Re: S2K ecu/cluster question true or false (EK project hybrid)
im pretty sure its the ECU...
i know the EVO also has digital miles, and when my friend intalled his EMS he was able to have the option to change the miles...
Old Dec 16, 2005 | 12:41 PM
blkturbos2k's Avatar
The miles are not on the ECU. I run AEM and I still have all my miles. I have never seen a Honda set up that way. Most are in the cluster, I dont know of any other way
Old Dec 16, 2005 | 09:12 PM
Francesco's Avatar
Default Re: S2K ecu/cluster question true or false (blkturbos2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blkturbos2k &raquo;</TD></TR><TR><TD CLASS="quote">The miles are not on the ECU. I run AEM and I still have all my miles. I have never seen a Honda set up that way. Most are in the cluster, I dont know of any other way</TD></TR></TABLE>
can you change the miles with the AEM, or its not an option for the s2k?
Old Dec 16, 2005 | 09:14 PM
Default Re: S2K ecu/cluster question true or false (Francesco)
Im use to the miles being recorded on the cluster. Never thought honda would get so technical. Any1 else?
Old Dec 16, 2005 | 10:38 PM
Mike_C's Avatar
memory in the cluster.
Old Dec 16, 2005 | 10:40 PM
Default Re: (Mike C)
Mike are you %100 sure? If so your a life saver...
Old Dec 16, 2005 | 11:33 PM
Mike_C's Avatar
99%... ecu simply doesn't make sense.
Old Dec 17, 2005 | 09:52 PM
I did some research on s2ki and I came across some news, some members mentioned that the cars mileage will reset back to zero on the cluster if it was changed. Some still say the cars mileage is recorded on the cluster and there still are some claiming the cars ecu is what records the mileage. Calling all s2k gods, give me a answer
Old Dec 18, 2005 | 08:28 AM
pwrofdrm's Avatar
As far as I know it's both. The milage is recorded by the cluster, but the ECU also knows the milage of the car. What leads me to believe this is that I know someone who bought an S2k without a cluster (stolen), but replaced it and was able to reset the milage from the ECU.
Old Dec 18, 2005 | 09:28 AM
BoostFrenzy.com's Avatar
Default Re: S2K ecu/cluster question true or false (.no tork.)
It's probably both. The ECU monitors the mileage.. If the cluster is ever changed out, the ECU still holds the mileage but under the original # from the original cluster. The ECU then probably keeps track of the mileage for the new # from the new cluster. The cluster probably has memory also and keeps the mileage as to display it correctly.
Old Dec 18, 2005 | 10:03 AM
Kenso's Avatar
HT White Ops
Default Re: S2K ecu/cluster question true or false (Mafiozo)
It's stored in the cluster (at least up to '04, haven't dealt with anything beyond that). I've swapped ecu's and the mileage did not change. Work at a dealership in case anyone wonders how I was able to swap ecu's with the immobilizer system.
Old Dec 18, 2005 | 12:28 PM
Default Re: S2K ecu/cluster question true or false (Kenso)
Awesome, I was hoping to run into someone that witnessed this scenario fist hand. Thanks for the info, you are the s2k god
aemintgsr
Acura TSX
Nov 12, 2011 05:06 AM
notmightydx
Honda Civic (2006 - 2015)
Aug 18, 2009 01:29 PM
Jap_Spec_Imports
Apr 6, 2008 12:59 PM
b20integrapower
Honda S2000
17
Jul 1, 2007 11:25 PM
BlueIntegraBoy
Jan 20, 2004 10:52 AM
