My car smokes more than ME!
Old Dec 15, 2005 | 09:43 PM
john666's Avatar
Default My car smokes more than ME!
put a d15b in my car.. starts up and runs without bogging, once it gets to running temp it shoots out alot of white smoke... Changed the head gasket.. started it up and sat back to see the same amount of smoke as before.. car still drives without bogging,, but tons of smoke as i rev up.. what else should i be looking at to solve my problem. any input would be nice.
Old Dec 15, 2005 | 09:45 PM
dohcVTECeg2's Avatar
Default Re: My car smokes more than ME! (john666)
did u check the timing?
Old Dec 15, 2005 | 09:48 PM
john666's Avatar
Default Re: My car smokes more than ME! (dohcVTECeg2)
forgot to mention its all white smoke.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcVTECeg2 &raquo;</TD></TR><TR><TD CLASS="quote">did u check the timing?</TD></TR></TABLE>
didnt check timing yet.
Old Dec 15, 2005 | 10:03 PM
old man neri's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by john666 &raquo;</TD></TR><TR><TD CLASS="quote">forgot to mention its all white smoke.
didnt check timing yet. </TD></TR></TABLE>
Sounds like coolant for sure. Did your gasket seat correctly, you might have a warped head or block. might have a crack also.
what is the condition and level of your coolant?
Old Dec 15, 2005 | 10:21 PM
john666's Avatar
Default Re: My car smokes more than ME! (old man neri)
gaskey was in correctly.. no idea if the head or block is warped or whatnot.. the motor had no problems when it was in my friends car but when it went into mine. it was smoking.. just changed injectors to see if that is a possible problem
Old Dec 15, 2005 | 10:23 PM
littleredcivic's Avatar
did the motor get tipped over or was upside down? there may be fluids in the intake manifold...
Old Dec 15, 2005 | 10:38 PM
BlackYoshi's Avatar
Default Re: (littleredcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by old man neri &raquo;</TD></TR><TR><TD CLASS="quote">
what is the condition and level of your coolant?</TD></TR></TABLE>
Cylinder head gasket may be bad or your cylinder head may be warped or cracked but in the worst case the engine block may be cracked
Old Dec 16, 2005 | 12:49 AM
WayQuiz's Avatar
sounds like ur head is warped. did you get the head resurfaced when you replaced the head gasket?
Old Dec 16, 2005 | 12:54 AM
john666's Avatar
Default Re: (WayQuiz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WayQuiz &raquo;</TD></TR><TR><TD CLASS="quote">sounds like ur head is warped. did you get the head resurfaced when you replaced the head gasket?</TD></TR></TABLE>
no i didnt.. i was kinda in a rush to get going so i didnt do that... what really gets me is that when this motor was in my friends car it had no problems. but as soon as it hit my car. bam!
Old Dec 16, 2005 | 11:11 AM
SOHCVTECx2's Avatar
In that case since you're smoking still after you changed the head gasket, you rings on your piston must be bad.
Old Dec 16, 2005 | 03:20 PM
BlackYoshi's Avatar
Default Re: (SOHCVTECx2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHCVTECx2 &raquo;</TD></TR><TR><TD CLASS="quote">In that case since you're smoking still after you changed the head gasket, you rings on your piston must be bad.</TD></TR></TABLE>
Not rings because he said it shoots white smoke = water leak if it was shooting a blueish tint then he might have to replace rings or whatever to fix a oil leak
JDMHondaEJ8
52
Apr 29, 2008 03:33 PM
Cbermin1
38
Sep 4, 2007 05:39 PM
Baodalazi
Jan 15, 2007 07:18 AM
Enzo PR
Jan 1, 2006 08:13 PM
fe519
Jan 5, 2004 01:59 PM
