Needs help with wiring Halo Ring headlights (NOT ONE PIECE)
Old Dec 15, 2005 | 07:48 PM
accordisslow's Avatar
Default Needs help with wiring Halo Ring headlights (NOT ONE PIECE)
Hey i know this might be a dumb question to some but i need help doing this crap.... Its complicated and im SOL so i turned here ..... i bought these headlights but it comes with way tomany plugs to wire to and i need to know where they go i kno one of them goes to Hi beam and other to low bean but what about the rest?
i bought these headlights... they are not one peice....
VVVV
and i know these go to one hi and one low beamVVVV
i need to know where these go.....they look like they hoook up to the corner lamps bulbs and i tried connection them there and i guess it goes there but what about the corner lights???
it has light two plugs to it check it VVV
and finally i need to know where do these two wires go to?
They come off of the houseing of the light. maybe the halo ring and if so what do i hook it up to?
^^^ this is to show that it is not once peice headlight
And i am installing them on a 1994 Honda accord LX
Old Dec 15, 2005 | 08:48 PM
RiceRocketDave's Avatar
Default Re: Needs help with wiring Halo Ring headlights (accordisslow)
You are right on the first three...the one that you thought plugs into the corner lights does and it should provide power to the middle projector too. As far as the two wires coming out by themselves they are for the halos. You can wire them up to where ever you want (switch parking. lights, ect....). Mine are connected to the parking lights for ease of install.
Old Dec 15, 2005 | 10:11 PM
Default Re: Needs help with wiring Halo Ring headlights (RiceRocketDave)
okay thanks thats cool ill let you know how it turns up tomorrow but what do i do about the corner lights? how are they suppose to light up? or is just one bulb in the corner light suppose to light up?
lol do you have the same lights? and what corner lights did u go with?
Old Dec 16, 2005 | 08:56 AM
The one for the corners if I remember right that should just plug into one of the leads and it will provide power to the middle projector. Both side-marker lights will work, if they do not then you did it wrong.
Here are a few shots of mine.
Old Dec 17, 2005 | 08:16 AM
hmm is it me or do my Halo dont really show up or could it be because the projector that is in the middle with the halo is on? and is there anyway to brighten the halo up? and also what wattz H3 bulbs do u use i got 55w but i think they are TOOOOOO weak lol and somehow my headlights point down lol is that okay?
Old Dec 17, 2005 | 08:39 AM
I never used the bulb inside the halo for that same reason, you could not see the halo lit at all. I just took the bulbs out.
As far as the light output...yes they do suck really bad. Do not go any higher than a 55W bulb or you will take the chance of damaging the harnesses.
As far as the aim goes, the little screws on the back side of the housing are the screws to adjust the projectors. Just take it to a dark empty parking lot and make sure they are adjusted to your liking. This is the part that took me the longest, I was tweaking on them for a good 2 weeks to get them perfect.
If you are really disappointed about the light output, do what I did and but hid's, and you will get the people that say "only do a retrofit" but with the projectors in these lights the cutoff is very good, there is hardly any glare above the cutoff at all.
I got mine from http://www.hid-lights.com they are the 8000k X5 kit.
BeRightBack
Oct 9, 2010 06:07 PM
ej6hatchie
Lighting
Jun 3, 2008 06:16 PM
truevietluv636
15
May 4, 2007 09:02 AM
fthesys
Apr 2, 2006 08:43 PM
hobo79
Jan 28, 2004 10:02 PM
