crx b16 problems
Old Dec 15, 2005 | 07:34 PM
sf_burgandyHatch's Avatar
Default crx b16 problems
my friend just did a b16 swap in his 90 crx. for some strange reason its running like crap. even weirder it will run off of 1 cylinder. it also is burning very rich and smoking black with a blue tint. can anybody give me some advice on what can be causing this?
Old Dec 15, 2005 | 07:41 PM
lodo1's Avatar
Default Re: crx b16 problems (sf_burgandyHatch)
blue tinted smoking is burning oil. i really dont think it would run off of 1 cylinder
Old Dec 16, 2005 | 10:31 AM
crxtreme89h's Avatar
Just a step toward fixing your problem. If everything is correct then we will go to the next step.
Modified by crxtreme89h at 7:43 PM 12/16/2005
Old Dec 16, 2005 | 11:21 AM
NikoZai's Avatar
Default Re: crx b16 problems (crxtreme89h)
Certainly check your firing order, points in the distributor.. but since you're getting blue smoke, and nothing timing wise can cause that.. i would check your headgasket.
Look for bubbles in the radiator by undoing the radiator cap at cold idle, and letting it warm up with the cap off. If you see bubbles, you've got a blown Head Gasket. Air in the coolant lines can only really be forced in by the cumbustion chamber itself.
Topshot
Jan 7, 2012 06:15 PM
lsEj8-V
15
Nov 24, 2011 04:00 PM
nonvtec92
11
Jun 24, 2008 10:06 AM
shackler
10
Jul 18, 2007 10:56 PM
Type R
Nov 22, 2001 03:09 PM
