Mugen ECU and Valve Spring Set....
Old Mar 16, 2002 | 01:51 PM
FAKEMEOUT_TYPE-R's Avatar
Default Mugen ECU and Valve Spring Set....
What you guys think about installing Mugen N1ecu and valve spring to get vtec to engage at 4700rpm and hit redline at 9100rpm....anybody try this set up yet?. I'm thinking about it and where can I get some and not break the bank.
Old Mar 16, 2002 | 01:52 PM
B2FiNiTY's Avatar
Default Re: Mugen ECU and Valve Spring Set.... (01-TYPE-R)
The mugen valve springs are the same as stock ones. Don't get the ECU unless you have other mods.
Reid's Avatar
Global Moderator
It was determined that Mugen valvesprings are indeed stock ITR valvesprings.
Old Mar 16, 2002 | 02:01 PM
Rob :190:'s Avatar
Default Re: Mugen ECU and Valve Spring Set.... (Reid)
i believe there is no point revving past stock redline on stock cams either...someone feel free to correct me.
Old Mar 16, 2002 | 04:15 PM
Gansan's Avatar
Are you sure we determined that? I remember translating/quoting from the Mugen literature where they clearly state that they are different/reinforced.
Old Mar 16, 2002 | 04:23 PM
Reid's Avatar
Global Moderator
Default Re: Mugen ECU and Valve Spring Set.... (Gansan)
Esteban Gonzalez was the one whose first-hand account revealed that Mugen valvesprings and stock ITR valvesprings are one in the same. Though I'm sure the Mugen valvesprings come in a nice Mugen box. Maybe when they mentioned different/reinforced they were referring to the box?
Old Mar 16, 2002 | 05:27 PM
Tommy_Gunns's Avatar
Default Re: Mugen ECU and Valve Spring Set.... (B2FiNiTY)
Really? So I can safely rev to 9200 rpm all day long on a road course (not that I can due to my stock ECU)?
I thought they were stock ITR springs that have been heat treated to handle high stress at longer intervals?
We can verify this buy looking at the grain structure of the metal under a microscope. If anybody wants to donate to me a sample of a Mugen valve spring, I can varify this.
Oh, and I'll need one stock ITR spring as well to compare.
[Modified by Tommy_Gunns, 8:28 PM 3/16/2002]
Old Mar 16, 2002 | 06:05 PM
xtrafastcivic's Avatar
Default Re: Mugen ECU and Valve Spring Set.... (Rob1035)
you can make power past 8200 on itr cams. cam gears will do the trick. and if you rev past 8200 and shift to the next gear you will be in a strong power band of the itr cams, so my conclusion is yes raise the rev limiter but not on a stock motor, it will do nothing
Old Mar 16, 2002 | 06:43 PM
Bob#455's Avatar
Yes, but what was determined at the same time was that Mugen sells these springs specifically for pre-98spec ITRs and CTRs. The valve springs were changed for the '98 models...so for all but 350 of our USDM cars, it won't do a thing. I believe that King's website is misleading, but Mugen has always said that the valve springs were not necessary for '98 and up.
Old Mar 16, 2002 | 07:14 PM
905_S2K's Avatar
New User
Default Re: Mugen ECU and Valve Spring Set.... (Bob#455)
I used to have Mugen Valve springs, then it went BUST on me.. I cracked one of them. Now i use Toda Valve spings. What is the Diff between Toda and stock R valve springs?? Can anyone explain?
cloud0084
May 13, 2010 04:51 PM
Turbo_EK
Nov 20, 2003 02:06 PM
gmsu00
Nov 26, 2001 07:51 AM
typerlover
Oct 4, 2001 06:42 AM
