auto harness in maual car
would i encounter any problems or cel's if i use a automatic wire harness in a manual car? reason is i have a dx and my wire harness is a mess and i can ge ta ex harness from a car that auto.
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wob »</TD></TR><TR><TD CLASS="quote">no problems, just eliminate the plugs used on the auto trans and use ones for a manual.. just make sure nothing thats needed is left unplugged</TD></TR></TABLE>
and if he didnt then what will happen?
His **** will blow up...derf... No, but really,I'm not sure if that was a serious question or not... Wat happens if u leave a vss unplugged... Ur speedo doesn't work..u leave ur reverse sensor unplugged..no reverse lights..how about forgetting to plug in ur starter?... Looks like ur push starting... Everything else could possibly throw a cel...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wob »</TD></TR><TR><TD CLASS="quote">His **** will blow up...derf... No, but really,I'm not sure if that was a serious question or not... Wat happens if u leave a vss unplugged... Ur speedo doesn't work..u leave ur reverse sensor unplugged..no reverse lights..how about forgetting to plug in ur starter?... Looks like ur push starting... Everything else could possibly throw a cel... </TD></TR></TABLE>
What the expletive are you talking about?
first of all the garage which swaped my tranny SUCKS his work was not clean at all
when I swaped a manual trany in my 96 ex there was no reverse lights and the speed gauges went crazy up and down, later on i took it to another garage and as he said (i canceled some wires which used to be on the car when it was automatic)
and after that the lights worked fine so did the gauges but the check engine light was still on (some people said because i'm using the automatic ecu and i have to get a manual ecu).
so i was wondering if there is anything else that i have missed !
that garage really sucks Fu*k it.
it has been 3 months since i swaped a manual trany and i'm still pissed when i remember that garage !!!!
...when I swaped a manual trany in my 96 ex there was no reverse lights and the speed gauges went crazy up and down, later on i took it to another garage and as he said (i canceled some wires which used to be on the car when it was automatic)
its really a straight foward swap i just did it on my 98 civic ex and my bros 00 civic ex. The automatic harness works fine, there are like 4 plugs that get unused on the automatic. The only plugs u need on the manual are the speedo and reverse everything else is mechanical. The only plug u will be missing is the plug for the idle air control valve on the back of the manifold, because the auto iacv is 3 wire and manuall one is 2 wire, all u have to do is solder the 2 wires from the manual iacv to the auto iacv plug. u dont need a plug. And of course u have a CEL if you running a auto ecu in a manual car u need a manual ECU. Any more questions im me.
Off topic, if you're thinking of doing an auto/manual swap on your EG/EK. Refer to these two threads, they're the best out there.
EG
https://honda-tech.com/zerothread?id=1316692
EK
https://honda-tech.com/zerothread?id=1337459
EG
EK
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbigg9032 »</TD></TR><TR><TD CLASS="quote">The only plug u will be missing is the plug for the idle air control valve on the back of the manifold, because the auto iacv is 3 wire and manuall one is 2 wire, all u have to do is solder the 2 wires from the manual iacv to the auto iacv plug. u dont need a plug.</TD></TR></TABLE>
Thnx for the info bro
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EJ1 »</TD></TR><TR><TD CLASS="quote">Off topic, </TD></TR></TABLE>
whats ur problem ?
whats ur problem ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbigg9032 »</TD></TR><TR><TD CLASS="quote">its really a straight foward swap i just did it on my 98 civic ex and my bros 00 civic ex. The automatic harness works fine, there are like 4 plugs that get unused on the automatic. The only plugs u need on the manual are the speedo and reverse everything else is mechanical. The only plug u will be missing is the plug for the idle air control valve on the back of the manifold, because the auto iacv is 3 wire and manuall one is 2 wire, all u have to do is solder the 2 wires from the manual iacv to the auto iacv plug. u dont need a plug. And of course u have a CEL if you running a auto ecu in a manual car u need a manual ECU. Any more questions im me. </TD></TR></TABLE>
so would i have to repin anything by the ecu for the iacv? btw i'm using a manual ecu.
b20vtecEK
May 3, 2004 11:12 PM
NatedoggAZ
13
Nov 26, 2003 10:20 PM
