d16y8 swap
Old Dec 15, 2005 | 04:50 PM
hondaefhatch89's Avatar
Default d16y8 swap
i have a 88 crx and i what to swap the sohc d16 into it and i was wondering if i need to get mounts for that or will it drop in and if not if i keep stock si crx tranny will it bolt up to the d16y8
Old Dec 15, 2005 | 05:28 PM
31flavorscivic's Avatar
Default Re: d16y8 swap (hondaefhatch89)
Stock tranny will bolt up, and it will drop in.
Old Dec 15, 2005 | 06:22 PM
jdmcars.com's Avatar
Default Re: d16y8 swap (31flavorscivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 31flavorscivic &raquo;</TD></TR><TR><TD CLASS="quote">Stock tranny will bolt up, and it will drop in.</TD></TR></TABLE>
You will need to use the 88 clutch/flywheel set up if using the stock 88 tranny.
You will have all the parts needed between the two engines, just a way to control the needed fuel mapping and vtec are the only things left.
Old Dec 16, 2005 | 02:28 AM
Default Re: d16y8 swap (jdmcars.com)
i was just wondering thought if i could use the d16 tranny of the ex
Old Dec 16, 2005 | 02:37 AM
89 pos's Avatar
if the ex tranny belongs to the d16y8 it will not work, keep your si tranny trust me
Old Dec 16, 2005 | 03:19 AM
Serdar's Avatar
Default Re: d16y8 swap (89 pos)
you should convert to obd1 and run a p28 ecu.
Old Dec 16, 2005 | 03:51 AM
JH4DC231's Avatar
Jay
Default Re: d16y8 swap (Serdar)
You're going to LOVE this car when you drive it after the swap
stylez vangundy
15
Apr 27, 2011 12:57 AM
projekt-sol
Dec 10, 2007 03:32 PM
HKS_USA
Mar 8, 2007 10:25 AM
Evil_Pull
Dec 14, 2004 04:53 AM
Davanca
Aug 12, 2003 05:45 AM
