what size nut is this when I'm replacing the oil cooler o ring? pic
Old Dec 15, 2005 | 02:54 PM
piggydog's Avatar
Default what size nut is this when I'm replacing the oil cooler o ring? pic
thx
Old Dec 15, 2005 | 06:25 PM
93h22a1vtec's Avatar
Default Re: what size nut is this when I'm replacing the oil cooler o ring? pic (piggydog)
bump, im to lazy to break out the honda service manual
and i need to take that shti off and see if my oil is being blocked from goin back into the block, cause my ****** oil filter gasket keeps getting blown out. expletive ****, fresh rebuild, need to take it to dyno and cant cause of this ****.
Old Dec 15, 2005 | 09:23 PM
MadCityLude
Guest
Posts: n/a
Default Re: what size nut is this when I'm replacing the oil cooler o ring? pic (93h22a1vtec)
I am pretty sure it is a 36mm. But I used a 1 3/16. And it worked fine.
Old Dec 15, 2005 | 09:27 PM
PrecisionH23a's Avatar
Default Re: what size nut is this when I'm replacing the oil cooler o ring? pic (KillaLude92)
30mm
The only thing that's a 36mm is the axle nuts.
Old Dec 16, 2005 | 06:02 PM
JDmahmed's Avatar
Looks to be a pretty big sized nut, almost close to the size of yo mama's. How do I know this? I go to pick up the ho off the street, we hit a motel, and all of a sudden, BAM!!!!!! She tells me shes a tranny (and i'm not talking hydro either). In any case, I had to bitch slap that ho and send her wack *** back to the street corner. As for the oil cooler O ring, my **** wouldnt even fit between it if it was cut in half. If you have any more questions, feel free to swing from these.
Old Dec 17, 2005 | 05:42 AM
pentaq's Avatar
Default Re: (JDmahmed)
check this https://honda-tech.com/zerothread?id=1462356
92redhatch
Jun 8, 2009 05:00 AM
djbrandonr
Jan 26, 2009 05:26 AM
HeikDiesel
Oct 5, 2005 07:13 PM
redboost10
Feb 24, 2004 11:14 AM
