need help removing a broken bolt...
Old Dec 15, 2005 | 02:22 PM
idriveadelsol7's Avatar
Default need help removing a broken bolt...
I have broken about ½ the length of stud that holds the exhaust manifold (header) on my block. Any suggestions? I’m not sure if I should take a vise grip to it or just have a machine shop remove it for me. Cannot fit any sort of drill in there so the EZ-out extractor set is useless. I want to remove all of them an jus use bolts instead while I’m at it. thanks in advance
Old Dec 15, 2005 | 05:53 PM
Eddiebx's Avatar
is there still enoguh threads stikcing out of the block so u can grab it with some visegrips? if so just spin it out
Old Dec 15, 2005 | 06:23 PM
fabrak8rX's Avatar
Default Re: need help removing a broken bolt... (idriveadelsol7)
if theres enough sticking out, a stud remover is a good option and a nice addition to your tool box as well -
Old Dec 15, 2005 | 07:30 PM
mike_belben@yahoo.com's Avatar
From: not riding any bandwagons in, massachusetts, usa
a stud in the head flange? why not just leave it alone? is it leaking?
Old Dec 15, 2005 | 09:53 PM
Default Re: (mike_belben@yahoo.com)
there's not enough 2 get a good grip with the vise ...
Old Dec 16, 2005 | 04:46 AM
fabrak8rX's Avatar
Default Re: (idriveadelsol7)
if its that short I usually just weld a peice of flat strap to it and back it out. if you dont have access to a welder, i guess id take it to your nearest shop -
Old Dec 16, 2005 | 07:54 AM
Default Re: (fabrak8rX)
flat strap?.... i was thinking about welding a nut 2 it
Old Dec 16, 2005 | 08:38 AM
splitime's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by idriveadelsol7 &raquo;</TD></TR><TR><TD CLASS="quote">flat strap?.... i was thinking about welding a nut 2 it</TD></TR></TABLE>
If you can get a nut on it to weld, that should work great, i'd spray the stud with some pb blaster for awhile first though, to at least let it loosen. Then tack weld nut and wrench.
Old Dec 16, 2005 | 10:42 AM
Default Re: (splitime)
yeah... i'm thinking about having a muffler shop help me out.
Old Dec 16, 2005 | 02:43 PM
snoochtodanooch's Avatar
i run the engine or take a torch to it to get the block hot. I bet it would come out pretty easy with vice grips.
Old Dec 17, 2005 | 06:00 AM
fabrak8rX's Avatar
a nut should work fine, vicegrips work too, hell ive had it where it shears off and then came back the next day and took it out with my fingers, (ok that only happened once) but just depends how bad its fused in there -
i prefer the strap because i can run a bead all the way around the shoulder as opposed to just the end, and the strap sits flush to the surface so it cant twist and or rock off axis which will shear whats left of it off flush.
its not the only way, - ive just had mixed luck with other methods, like anything else it trial and error over time, but this set up hasnt failed yet.
Old Dec 17, 2005 | 07:16 AM
Formula Racing's Avatar
Default Re: need help removing a broken bolt... (fabrak8rX)
I had that problem on a turbocharged RX-7.
I used a die grinder for about 3 days and finally got it to a point I could remove most of it by sticking a screwdriver into the remnance of the thread.
tegboy321
21
Jul 28, 2013 02:58 PM
jorge59la
Jun 18, 2008 02:57 PM
idriveadelsol7
Dec 19, 2005 01:52 AM
Ceeveek
Jul 19, 2003 10:14 AM
