Oil catch can...already did search
I searched every topic about this subject. I picked up an Endyn breather tank kit which is actually made for a B20 but i was told by Rick at Endyn that it would work on my B18C5.
I mounted it cleanly and everything. I am having a few problems though. The directions indicate for the B20 obviously so i am not quite sure how to hook this thing up. I have the drainback hoses and fittings in place to the back of the block. The can came with 4 openings: one on top, two on the side of the can, and one little opening at the bottom. I plugged one of the fittings on the side. I used one of the opening for 1/2 inch hose to go to the back of the block (drainback) and also the little opening on the bottom for 3/8 inch hose to tee into that 1/2 inch hose for drainback. So now i am assuming that the PCV hose needs to go to the top of the catch can as opposed to the intake manifold? If this is the case, what happens to the vaccum on the intake manifold? Where would that hose go? This is all confusing me. Like is said i read through all the previous posts and did not collect the info i needed. I already loaded the cylinders up with oil installing it wrong!
Now i need the right info from the experts. Thanks guys.
Mike
Now i need the right info from the experts. Thanks guys. Mike
You will need to disconnect the stock hose that goes from the PCV to the intake manifold. After that, connect a hose running from the PCV to the catch can and then a from the catch can back into that PCV.
That's what I mean by PCV -> Catch Can -> Intake Manifold
Ok i did that originally. I put a tee on the hose from the intake manifold to the PCV and went to the top of the catch can. I guess the vacuum pulled **** right out of the can into the intake manifold and went into the cylinders and loaded it up with oil
what am i missing here?
Mike
Mike
not supposed to put a -T- fitting PCV hose goes INTO catchcan, anc another hose goes OUT, into intake manifold.
Mike
Mike
alright who wants to give me their phone number (i have free long distance with my cell phone on the weekends) and talk me through this thing? I have everything mounted and it would only take a few minutes. I just need for someone to talk me through it. Thanks a bunch.
Mike
Mike
just take out the T fitting.
see the red PCV valve on the left of my green "catch can?
a line from there STRAIGHT to the catch can, mount the catch can somewhere, then run another line from the catch can to the spot on the intake manifold where my "green catch can" is connecting to in the picture.
what catch can do youall reccomend and where can they be found online for the cheapest?
thanks
matt
thanks
matt
What are pro's and con's of having a catch can...I have noticed the amount of oil in my manafold..
How can a oil catch can help mem, and are there any disadvatage's to having it???
CONS: have to remember to empty the oil catch can periodically
In this instance, the PROS far outweigh the CONS.
BSQ, so i take it that the red PCV hose needs to go to the top of the catch can? What hose needs to be connected with the outlet on the intake manifold?
Mike
Mike
Good one! You live and learn. I never expect to be a mechanic but i want to learn the basics. Guess you have to make the mistakes and realize you can learn something from them.
Mike
Mike
