automotive primer? which one should i use?
Old Dec 15, 2005 | 12:04 PM
JCracer723's Avatar
Default automotive primer? which one should i use?
well i dont know if this is the right forum to ask. and ive been doin some search..so far i know there are different kind of primers out there, but im not sure which one is the one i should use..
my car its already wetsanded.. so which primer should i ask for? (poly.. epoxy.. urathane.. lacquer)
thanks
Old Dec 15, 2005 | 01:22 PM
B6tPoweredMx3's Avatar
Default Re: automotive primer? which one should i use? (JCracer723)
What kind of paint do you plan on spraying?
If you plan on spraying urathane (which is wonderful stuff i might add), use a primer that will work with urathane.
Some chemicals dont like each other and if you get a combo of the 2 they will chemically react and you will have a big ******* mess.
figure out what paint your using( or the shop) and buy the proper primer.
Old Dec 15, 2005 | 01:26 PM
JCracer723's Avatar
Default Re: automotive primer? which one should i use? (B6tPoweredMx3)
im sprayin John deere blitz black.. its an "air dry" paint.. they have their own primer but not on stock.. and its 45 bux a qrt.. at least that what they said..
Old Dec 15, 2005 | 04:47 PM
siblues's Avatar
He was talking about what type of paint like urethane epoxy or laquer because you have to get the right primer to go with it or the ywo will have a bonding issue and if you are doing the paintwork yourself I wish you good luck
H22EG'z
Paint and Body
11
Aug 6, 2010 09:03 PM
sandturtle
Paint and Body
Apr 18, 2008 08:57 PM
matmcg
Paint and Body
18
Mar 23, 2008 09:28 AM
zseeanz
11
Dec 13, 2002 08:59 PM
nkato
Mar 28, 2002 08:15 PM
