Wierd stuff going on!
Old Dec 15, 2005 | 11:45 AM
Idiotboy's Avatar
Default Wierd stuff going on!
Im running a 90 CRX HF, with a JDM SOHC ZC. When I get on the throttle someitmes the car does not increse engine speed. I can have the pedal to the floor and the car just bogs and sits at whatever rpm it was at before I gave it more throttle. Then like a bat out of hell it will sputter and then take off. I have no Idea what could be causing this, and it sucks. Also I have noticed a knocking sound comming from under the hood, I checked it out and I have no idea what that is. Everything checks out and its not consistant with engine speed, so I dont think its rod knock, any Ideas guys on either of these things?
Old Dec 15, 2005 | 11:48 AM
Old_Honda's Avatar
Default Re: Wierd stuff going on! (Idiotboy)
Do you have a check engine light? The first problem sounds like the throttle position sensor, which would be a code 7.
Old Dec 15, 2005 | 11:56 AM
Idiotboy's Avatar
Default Re: Wierd stuff going on! (OldGSR)
Ooops almost forgot, No, no codes guys, yeah I'll check the TPS. I looked at it before but it could be going wrong now that the weather is cold and **** seems to be breaking.
Winter=finding the weekest links in your ride
Old Dec 15, 2005 | 01:07 PM
Idiotboy's Avatar
whateevr was making that noise just broke, I got no power at all, the car boggs all the time
Old Dec 15, 2005 | 05:58 PM
1.6civicturbo's Avatar
check your distributor and and yur tune up parts. plugs.wires cap and rotor. it could also be your tps which was previsely mentioned
bbLUDE
Mar 22, 2008 09:46 AM
dc2integtypR
Oct 5, 2005 11:02 PM
B16 ED9
Oct 8, 2004 01:24 PM
Roger
Jul 15, 2002 09:16 PM
