New oil catch can routing.. Is this ok?
Old Dec 15, 2005 | 10:09 AM
rebo0t's Avatar
Default New oil catch can routing.. Is this ok?
My catch can was causing a vac leak when I had it routed to the stock PCV and to the intake manifold. So I did this for a quick fix unless its ok to just leave it as is. What I did was instead of getting vac from the intake manifold, I routed it to the intake pipe's nipple instead. I dont know if thats enough vac or maybe just vac at open throttle? As you can see in the picture, I Tee'd the valve cover into the stock PCV's line to the catch can.
So it goes: stock pcv --> valve cover --> catch can --> intake nipple. Do you guys think this is ok? Any downsides from doing this?
Also, I have an option to either run a filter on the can or not. I just need to drill and tap a small filter on it. You guys think I should put a filter on it since its getting vac from the intake? I need all opinions, thanks
Old Dec 16, 2005 | 09:11 AM
rebo0t's Avatar
Default Re: New oil catch can routing.. Is this ok? (rebo0t)
Old Dec 16, 2005 | 11:46 AM
rebo0t's Avatar
Ok, nevermind.. Doesnt work that way. Valve cover needs fresh air. Had it reversed.
SupraManAG
Aug 30, 2008 06:02 PM
Street Inc
Sep 11, 2005 08:20 PM
steve-o40
Apr 8, 2004 08:11 PM
AdamITR
Jan 26, 2003 10:23 PM
dingusjt
25
Nov 18, 2002 05:37 PM
