215 or 205 /45/16 for my 16x6.5 ???
I can't decide from 215/45/16 and 205/45/16 on my 16x6.5 wheels. I'm afraid 215 will be too wide and would not benefit the car. what would be the best for my wheels if any of you wheels expert out there.
ive got 215/45ZR17's on, my 5th gen, and they scrub a lil bit in hard cornering, and when you almost bottom out over bumps,,, but they feel much more solid than the last set of 205/40's i had on..
To keep closest to the stock outside tire diameter you would want to go with a 205/50/16 or a 215/45/16, these sizes will keep your outside tire diameter closest to stock, thus keeping your gearing closest to stock as well.
EDIT: Also, depending on the offset of the wheels and if you plan on lowering the car at all can also be deciding factors.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AEMPrelude916 »</TD></TR><TR><TD CLASS="quote">ive got 215/45ZR17's on, my 5th gen, and they scrub a lil bit in hard cornering, and when you almost bottom out over bumps,,, but they feel much more solid than the last set of 205/40's i had on..</TD></TR></TABLE>
i have the same size and setup, but no scrubbage. how low is yours? could be b/c i am only running eibach pros until my 12 pt coilovers get fabricated. waiting till spring, no point beating the hell out of a new suspension on winter potholes
Modified by limpmode at 3:30 PM 12/15/2005
thanks for the great analogy "preludeguy" and yes I want the tires to be a positive thing not looks or show. The tires I'm planning to use are the ventus 215/45/16 they go for about $97 a piece on tires.com they look pretty nice. I love the parada spec2 as well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by limpmode »</TD></TR><TR><TD CLASS="quote">
Modified by limpmode at 3:30 PM 12/15/2005</TD></TR></TABLE>
im running eibach also, it isnt event that low..., but the tires i got have a pretty good sized sidewall, bigger than any other 45's i ve seen.. it scrubs on the splash guard.. i had a decent sized fender gap, with the 205/40's , so i went with the 215/45.. and not my tires are tucking the fender in the front and rear... i think my springs have started to settle .. a lot...
215/50/16 is closest to stock for 5th gen while 215/45/16 is closest to stock on a 4th gen.
i run 215/45/16 hankook ventus rs-2 on my 4th gen. they're great and i definitely recommend them.
BassBoy19
Dec 12, 2003 07:34 PM
but they wear out pretty fast if you are a "spirited" driver
