dual fuel pump, but how?!?!
Hi,
A friend of mine got a drag 1991 CRX with B16A high compression pistons, NOS and stuff...
anyway, lately after he've raised the NOS jetting, he've been going lean at high rpm, so i guess the fuel pressure is going low at high rpm, he decides to go for a 2nd fuel pump....
So is it better to put both fuel pumps in the fuel rail? or 1 pump in fuel rail and the other going to the NOS selinoid?
o.. well why dont u get urself an intank fixture and also use the external
Dont have a fuel pump going to the NOS solenoids its unregulated if u run it like that....
You either need to open up the fuel nozzles a little soo that they dump more or tune it for the amount of NO2 ur spraying
I would stick to one GOOD fuel pump. the downfall to having two pumps is if one goes out you will never know at idle/cruising rpm but you will find out at higher rpm when you destroy your engine!
DroppedTegra
Jan 18, 2002 03:13 PM
