TIMING BELT??? Integra LS
Old Dec 15, 2005 | 08:39 AM
bman511's Avatar
Default TIMING BELT??? Integra LS
Ok, today i was sitting at a traffic light, light turned green, and the car kindof, well it didnt' go and then stumbled a little and died. I tried to crank it, realized there was no resistance and towed it home. Later to find out that my timing belt broke. It is a 95 LS....does anyone know how to set my camgears/crank pulley to where they need to be. I have been told that i would probably have to re-align everything again. Your help with this is greatly appreciated, and thankyou in advance!
Old Dec 15, 2005 | 09:47 AM
aeon's Avatar
i believe theres an article over at team-integra.net that can help
Old Dec 15, 2005 | 12:24 PM
00IntegrAllmotoR's Avatar
HT Black OPs
Default Re: (aeon)
This also might be a good time to upgrade to a ITR water/oil pump, but you will have to get a gsr timing belt.
Old Dec 15, 2005 | 12:25 PM
2ndName's Avatar
So let me get this straight.
Since I do have an LS, I can upgrade to an ITR Water Pump if I get a GSR Timing Belt?
What is usually the cost difference directly from a dealer?
Old Dec 15, 2005 | 12:33 PM
aeon's Avatar
I hear that it isn't good to upgrade to a vtec water pump on a non vtec car.
Old Dec 15, 2005 | 01:19 PM
HT Black OPs
Default Re: (aeon)
the itr water pump assy. is $94 and the oil pump is 94 also. For a 00 ITR
Then you could just get a nice aftermarket Timing belt like toda or greddy.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aeon &raquo;</TD></TR><TR><TD CLASS="quote">I hear that it isn't good to upgrade to a vtec water pump on a non vtec car.</TD></TR></TABLE>
Can you explain this? For FI or NA setup?
Old Dec 15, 2005 | 01:34 PM
aeon's Avatar
Default Re: (00IntegrAllmotoR)
I remember reading about it somewhere. It's not that it isn't good, but there is no advantage of using a vtec water pump in a non vtec motor unless you are planning on using a gsr/itr or kevlar belt. The vtec water pump is less efficient than the Ls.
found the article about the water and pil pump http://www.team-integra.net/fo...earch
article on changing the t-belt
http://www.team-integra.net/se...=1044
Modified by aeon at 4:05 PM 12/15/2005
Old Dec 15, 2005 | 06:13 PM
unseenforces1's Avatar
Default Re: TIMING BELT??? Integra LS (bman511)
i have a 95 integra ls also and i did mine timin belt and i used a website called alldata.com that wha we use in school hope dis helps
Old Dec 15, 2005 | 06:54 PM
Uncle Ben's's Avatar
Cogent Argument Enthusiast
Default Re: TIMING BELT??? Integra LS (unseenforces1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by unseenforces1 &raquo;</TD></TR><TR><TD CLASS="quote">i have a 95 integra ls also and i did mine timin belt and i used a website called alldata.com that wha we use in school hope dis helps</TD></TR></TABLE>
alldata is allgay. they dont have alot of useful information for alot of cars. use snapon shopkey
Old Dec 15, 2005 | 08:55 PM
HT Black OPs
Default Re: TIMING BELT??? Integra LS (benb18a)
^^ thank you for that post off of team-integra. i didnt think of it that way, and you just saved me money.
Justintegra
Apr 20, 2008 12:46 PM
racer034life
Jan 7, 2008 01:16 PM
wpsadmin
Oct 25, 2004 06:09 PM
lsvtechatch04
May 8, 2004 03:20 AM
vtecb20coupe
Dec 10, 2003 12:15 PM
