Lower compression pistons for FI.....is this possible?
Old Dec 15, 2005 | 07:57 AM
fredtoast's Avatar
Default Lower compression pistons for FI.....is this possible?
Is it possible to lower compression ratio by shaving down the stock pistons? If so how much reduction is possible.
Old Dec 15, 2005 | 10:06 AM
JDMEK206's Avatar
Default Re: Lower compression pistons for FI.....is this possible? (fredtoast)
it is possible but why would u risk ruining stock pistons. plus u can get new low comp ones for 400 or less. There is too much time and money spent by companies on piston top design for u to try it in one shot. just my 2 cents
Old Dec 15, 2005 | 10:19 AM
fredtoast's Avatar
Default Re: Lower compression pistons for FI.....is this possible? (djstation)
Thanks for the info. Do you know anyone who has actually had this done?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djstation &raquo;</TD></TR><TR><TD CLASS="quote">it is possible but why would u risk ruining stock pistons. plus u can get new low comp ones for 400 or less. There is too much time and money spent by companies on piston top design for u to try it in one shot. just my 2 cents</TD></TR></TABLE>
BTW, there are no after market parts for the engine I'm going to be boosting.
Old Dec 15, 2005 | 10:29 AM
rebo0t's Avatar
Don't think anybody has done this. But it is "possible". I think it would cost almost as much to custom a low comp stock piston as it cost to buy brand new low comp pistons. So really no point..
Old Dec 15, 2005 | 10:45 AM
JDMEK206's Avatar
Default Re: Lower compression pistons for FI.....is this possible? (rebo0t)
what engine are u boosting? custom pistons are 6-700 bucks if u wanted to know
Old Dec 15, 2005 | 11:00 AM
fredtoast's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djstation &raquo;</TD></TR><TR><TD CLASS="quote">what engine are u boosting? custom pistons are 6-700 bucks if u wanted to know</TD></TR></TABLE>
Toyota v6 (1mz-fe or 5vz-fe) swapped into a MR2.
Old Dec 15, 2005 | 11:07 AM
JDMEK206's Avatar
wow that is obscure...i'd say just get some custom ones to be safe. maybe try finding pistons of the same size from another car? what size bore is it?
Old Dec 19, 2005 | 06:30 AM
fredtoast's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rebo0t &raquo;</TD></TR><TR><TD CLASS="quote"> I think it would cost almost as much to custom a low comp stock piston as it cost to buy brand new low comp pistons. So really no point..</TD></TR></TABLE>
That's what I was thinking also. I just wanted to know if it was possible before I started asking about price.
BTW I come from the old, old school where one of the most common mods to an engine was shaving the head to increase compression.
Old Dec 19, 2005 | 04:35 PM
TunerN00b's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fredtoast &raquo;</TD></TR><TR><TD CLASS="quote">That's what I was thinking also. I just wanted to know if it was possible before I started asking about price.
BTW I come from the old, old school where one of the most common mods to an engine was shaving the head to increase compression.</TD></TR></TABLE>
Shaving a head is one thing, shaving pistons is another entirely, me thinks. In fact, there's usually a factory specified amount of the head thats safe to shave.
Depending on how much compression reduction you want, would a thicker head gasket work? You could also try finding slightly shorter rods, or remove some material from within the combustion chambers of the heads. If you are going to put new sleeves into the block, I suppose you could get slightly longer sleeves (1 or 2 mm), and use a deck plate (is that the correct term?).
Old Dec 20, 2005 | 07:06 AM
fredtoast's Avatar
So has anyone ever had pistons "fly cut" to get more valve clearance?
Doesn't that effect the compression ratio?
Old Dec 21, 2005 | 11:39 AM
fredtoast's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fredtoast &raquo;</TD></TR><TR><TD CLASS="quote">So has anyone ever had pistons "fly cut" to get more valve clearance?
Doesn't that effect the compression ratio?</TD></TR></TABLE>
Anyone?
Old Dec 21, 2005 | 12:54 PM
98_4drCivic's Avatar
never had it done, but yes it would lower compression very slightly.
michaelprice83
Apr 7, 2008 05:55 PM
fredtoast
Dec 21, 2005 03:33 PM
Hy-wind
Dec 2, 2004 04:18 AM
My_EP3
Apr 6, 2004 06:27 PM
I_know
Dec 21, 2002 07:07 AM
