pct pistons on your ITR
Old Dec 15, 2005 | 06:42 AM
boy_hapon's Avatar
Default pct pistons on your ITR
im using a sk2 st2 cams and upgraded valvetrain. i want to bump the compression to maximize the potential of my cams. i bought a pct pistons. i know the compression will be on the high side. i just want to know if anyone here running pct pistons on their ITR? will i be able to use it on the streets? does it ping a lot?
i plan to use chrome to tune it. thanks!
Old Dec 15, 2005 | 07:33 PM
vivid 02's Avatar
Default Re: pct pistons on your ITR (boy_hapon)
I had CTR pistons on my old b18c5 and I was tuned on hondata..... It pinged like a mother fawker at partial throttle. At wide throttle it was bit better. Going up hill was hell... so much pinging. 91 octane though.
Old Dec 15, 2005 | 08:25 PM
boy_hapon's Avatar
Default Re: pct pistons on your ITR (vivid 02)
thanks man! i need more info please! keep em coming.
btw what cams were you using?
Old Dec 15, 2005 | 10:10 PM
vivid 02's Avatar
CTR cams
Old Dec 16, 2005 | 09:19 AM
Rollo Lawson's Avatar
with PCT's your c.r. will be in the 13.0/1 area. i think that you need more than higher compression to benefit substantially. i'd reccommend headwork for your car. lastly, PCT's are the heaviest b series 81mm pistons. if it were me, i would mill the head to achieve the desired compression ratio. i think 11.3-11.8 c.r is good for those cams. i laugh when people reccommend pct's. i mean.. heavier piston, big dome, bad flame travel. i don't know. maybe its just me. anyway, g/l with the project.
Old Dec 17, 2005 | 07:25 PM
boy_hapon's Avatar
Default Re: (B16C1)
thanks! i think i'll just get the a flatfaced valves, thinner head gasket and mill the head a little to get me a little more compression. if i slap a pct piston my compression would be around 12.5-12.6 i think thats too high for me.
im going to have a head works done too. thank you for lending me sometime to help.
Old Dec 18, 2005 | 08:20 AM
len's Avatar
len
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boy_hapon &raquo;</TD></TR><TR><TD CLASS="quote">im using a sk2 st2 cams and upgraded valvetrain. i want to bump the compression to maximize the potential of my cams. i bought a pct pistons. i know the compression will be on the high side. i just want to know if anyone here running pct pistons on their ITR? will i be able to use it on the streets? does it ping a lot?
i plan to use chrome to tune it. thanks!</TD></TR></TABLE>
It's not the static compression you should be worried about, more so the dynamic compression and physical clearance issue. I've ran PCT slugs in my B18C5, but since my cams had so much duration there wasn't any issue with pinging or knocking.
Old Dec 19, 2005 | 02:25 AM
boy_hapon's Avatar
Default Re: pct pistons on your ITR (len)
i just read something about that im still studying it. i think the cam profile will play a big role in the dynamic compression. im still not ready to give up on my pct pistons. thank you very much!
Old Dec 19, 2005 | 05:35 AM
Rene M's Avatar
Default Re: (B16C1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16C1 &raquo;</TD></TR><TR><TD CLASS="quote">with PCT's your c.r. will be in the 13.0/1 area. i think that you need more than higher compression to benefit substantially. i'd reccommend headwork for your car. lastly, PCT's are the heaviest b series 81mm pistons. if it were me, i would mill the head to achieve the desired compression ratio. i think 11.3-11.8 c.r is good for those cams. i laugh when people reccommend pct's. i mean.. heavier piston, big dome, bad flame travel. i don't know. maybe its just me. anyway, g/l with the project.</TD></TR></TABLE>
http://www.c-speedracing.com/h...c.php
I see 12.09 to 1 ???
We have a B20 that is at damn near 13-1 on super right now? No ping?
Old Dec 19, 2005 | 05:54 AM
len's Avatar
len
Default Re: (Rene M)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rene M &raquo;</TD></TR><TR><TD CLASS="quote">?????
We have a B20 that is at damn near 13-1 on super right now? No ping? </TD></TR></TABLE>
Rene, Has C-Speed fixed their calculator yet?
Old Dec 19, 2005 | 06:05 AM
Shawn C's Avatar
In The Garage
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rene M &raquo;</TD></TR><TR><TD CLASS="quote">We have a B20 that is at damn near 13-1 on super right now? No ping? </TD></TR></TABLE>
i think people actually run their engines on stock computers, even with crazy setups. all these people talkin about pinging kill me. just take some damn timing out of the maps, people! gees...
and just so you guys know, a high dome is a retarded way to get high compression. a rounded triangle-shaped combustion chamber /_\ is the best design for combustion and for power. imagine an explosion pushing down on a slightly dished piston. pretty good idea, huh? the piston serves as a pocket to concentrate the explosion and direct the piston straight downward.
now imagine an explosion trying to push on the sides of a huge dome. doesn't seem too efficient, does it? well, it isn't. shave the head, or swap to a gs-r (P72) head, which has a smaller combustion chamber, and much bigger ports than a PR3 unit.
Old Dec 19, 2005 | 02:39 PM
SSA 1's Avatar
Default Re: (ShadyEH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ShadyEH2 &raquo;</TD></TR><TR><TD CLASS="quote">shave the head, or swap to a gs-r (P72) head, which has a smaller combustion chamber, and much bigger ports than a PR3 unit. </TD></TR></TABLE>
i thought the non r pr3 and the p72 flowed the same? where did you get this info?
kart_driver
26
Aug 31, 2010 01:07 PM
Chris
Aug 22, 2002 09:56 AM
IdotheSHOCKER
Jun 19, 2002 09:57 PM
blazin
Dec 4, 2001 06:34 AM
StinkyTofu
Oct 22, 2001 09:30 PM
