Water leak
I was wondering if anyone could help me with a water leak (rain) on my '96 accord DX, 4 door? I found some mention of a known water leak in a TSB however, it didn't have any details. The water pools in the driver and passenger front floor and the trunk. Any help would be appreciated in locating the source.
Thanks.
Thanks.
You have more than one leak sourse.
There is a raised section of floor under the rear seat (allows Fuel Tank Installation) which effectively seperates the front floor(s) from the trunk.
I'd first look at the Rear Tail Lamps Body Gaskets as a possible water leak sourse. (quite common)
For the front I'd suspect the windshield requires resealing, only because you mentioned BOTH sides.
P
P
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P_Adams »</TD></TR><TR><TD CLASS="quote">You have more than one leak sourse.
P</TD></TR></TABLE>
P- you are good
P</TD></TR></TABLE>
P- you are good
07AccordBC
May 4, 2012 12:13 AM
crxforum
Oct 30, 2006 01:15 PM
