tranny problems in a 90 integra RS HELP PLEASE!
Old Dec 14, 2005 | 07:09 PM
EB90RS's Avatar
Default tranny problems in a 90 integra RS HELP PLEASE!
i jus installed a jdm b16a1 tranny on my 90 integra RS with a GSR clutch but when it was installed it made these wierd noises. example when i shift into any gear it makes noises like somethingz spinning and clinking... i'm pretty sure my tranny is junk and the main bearing is screwed up but does anyone have any other idea or anything else they can think of that is wrong and making this noise? because my car still feels like it pulls hard and works find jus a lot crazy noises and sounds like its about to fall out.
Old Dec 14, 2005 | 07:25 PM
projectTeG's Avatar
um you might have used the wrong clutch depending on the type of trnasmission you have. if its a y1,j1, a1, or s1 type tranny they have smaller clutch splines then the 92-01 bseires trannys which the gsrs use.
Old Dec 14, 2005 | 07:32 PM
EB90RS's Avatar
Default Re: (projectTeG)
it's a y1.. so if it is a y1 then the clutch is to big for the tranny? that is one thing i thought to when i heard the noise but when i fitted the gsr clutch on the splines it fit perfectly. would that matter or not?
Old Dec 14, 2005 | 07:51 PM
projectTeG's Avatar
Default Re: (EB90RS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EB90RS &raquo;</TD></TR><TR><TD CLASS="quote">it's a y1.. so if it is a y1 then the clutch is to big for the tranny? that is one thing i thought to when i heard the noise but when i fitted the gsr clutch on the splines it fit perfectly. would that matter or not? </TD></TR></TABLE>
lol theres no gsr clutch out there that will fit the small splined trannies....all the gsrs had larger splined trannies. id say its the clutch.
Old Dec 15, 2005 | 07:30 PM
EB90RS's Avatar
yea thats exactly what i thought to but when i put the gsr clutch on the splines it didnt slip or anything at at all if fit exactly perfect and the thing is i took tha clutch off my old tranny and try to fit it on the y1 tranny and the splines on tha y1 was to big for my old clutch and the clutch wouldnt even go on?
Old Dec 15, 2005 | 07:47 PM
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EB90RS &raquo;</TD></TR><TR><TD CLASS="quote">yea thats exactly what i thought to but when i put the gsr clutch on the splines it didnt slip or anything at at all if fit exactly perfect and the thing is i took tha clutch off my old tranny and try to fit it on the y1 tranny and the splines on tha y1 was to big for my old clutch and the clutch wouldnt even go on? </TD></TR></TABLE>
that shouldnt have happen. are you sure you have a y1 and not a ys1? ys1's use the 92-01 clutches
Old Dec 15, 2005 | 08:03 PM
EB90RS's Avatar
yea im positive becuz i checked the tranny code before i installed it....pretty confused cause that's what i said to i dunno why it would fit that tranny and not the other
Old Dec 15, 2005 | 08:54 PM
EB90RS's Avatar
im going 2 recheck the tranny code jus to make sure but if it is a ys1 then does that mean tha tranny is jus junk or what do you think?
Old Dec 17, 2005 | 11:15 AM
EB90RS's Avatar
bump... and it is a ys1
Old Dec 17, 2005 | 11:48 AM
projectTeG's Avatar
did you install the throw-out bearing right?
E9CiViC1F
Aug 25, 2009 02:55 PM
slammed4dreg
Feb 9, 2008 02:39 AM
jdm420da6
Feb 1, 2004 11:52 AM
ILOVEGIRLS
Feb 25, 2002 04:10 PM
