alternator/ starter swap
From: if you build it they will come, the bottom carolina, duh
i was wondering if anyone has ever tried to swap an alternator from a 90 crx si stock engine into a crx si with a b16 swap and if it worked.
thanks in advance
thanks in advance
also for the obd1 conv. do you need the obd1 dizzy or stay with the obd0, and can i use a dizzy off of a single cam vtec head
so are you saying that if i do a obd1 swap that i have to get the obd1 dizzy or can i stay with the obd0 dizzy?
thanks for the other info.
white90rexsi
Jan 2, 2007 07:55 PM
pinecone
13
Jun 5, 2006 07:11 PM
