Rebuild my d16a6 or go with a d15b?
Old Dec 14, 2005 | 03:23 PM
92civeg's Avatar
Default Rebuild my d16a6 or go with a d15b?
i was just wanting to get some opionions on the subject. I can completely rebuild my d16a6 longblock or swap in a 60k mile d15b longblock for the same price.
I like the fact that i wont have to search for parts with the d16a6 if something ever fails...but i might have to research the d15b part to find its usdm counterpart ( or is there usdm motor that all parts can be taken from maybe a d16z6?)
eitherway please give me some opionions on which route to go and which do you think will be quicker
thanks
Old Dec 14, 2005 | 03:39 PM
jisu009's Avatar
Default Re: Rebuild my d16a6 or go with a d15b? (92civeg)
rebuild.
A6's are pure.
Old Dec 14, 2005 | 04:07 PM
UltimX's Avatar
Default Re: Rebuild my d16a6 or go with a d15b? (jisu009)
which d15b are you getting? that will determine weither or not u should switch out the engines. I personally like the a6. if you want some more power, get a cam and put some oversized pistons in since ur rebuilding
Old Dec 14, 2005 | 06:58 PM
92civeg's Avatar
Default Re: Rebuild my d16a6 or go with a d15b? (UltimX)
d15b vtec 130hp
more opinions please!
Old Dec 14, 2005 | 07:07 PM
AJxr's Avatar
keep the a6, i was going to get a vtec d15b but backed out and decided just to build my a6. for that money for the d15b (engine, harness, ecu) you can build your a6 and have just as much hp. unless money isn't an option, or if you WANT vtec go with a mini me swap since your rebuilding the motor anyway although if you do it correctly and get an ecu and harness in the end the price tag may be the same as the d15b swap.
d16a6
Old Dec 14, 2005 | 08:00 PM
Surewin's Avatar
If you don't mind rewiring your car to OBD-1, go D15B vtec. If not, stick with the A6. You can always bolt on a Z6 vtec cylinder head and buy a Zydne one wire ECU.
Yes all maintenance items for the D15B can be found in the US.
Old Dec 15, 2005 | 03:54 AM
92civeg's Avatar
Default Re: Rebuild my d16a6 or go with a d15b? (Surewin)
bump.
Old Dec 15, 2005 | 04:21 AM
Timmah!!'s Avatar
Rebuild with a nice valve train and cam. If I had an A6, I would have kept it.
Old Dec 15, 2005 | 06:45 PM
92civeg's Avatar
Default Re: Rebuild my d16a6 or go with a d15b? (Cobra Tim)
well it turns out that the d15b is gonna be cheaper soo i think im just gona do that...anyone had any experience with one of there in a crx?
Old Dec 15, 2005 | 09:14 PM
ZCVTEC-SOHC's Avatar
From: PhantomGrayEH2, CA Where Gay Arnold Rules, USA
If you don't want to bother looking for D15B parts and want a low mileage SOHC VTEC engine go with a SOHC ZC VTEC. Exactly the same as a D16Z6 and you won't have no problems looking for parts ever.
Garcia505
10
Feb 21, 2010 05:21 PM
SkyCivic92
Jul 8, 2009 10:32 AM
phondataz
Jan 27, 2007 10:00 AM
allmotoralldayeveryday
118
Aug 17, 2005 07:05 AM
TehMoonRulz
Apr 10, 2005 10:30 PM
