prelude h22a swap (wire harness quetion HELP!!!)
Old Dec 14, 2005 | 03:16 PM
jc8251123's Avatar
Default prelude h22a swap (wire harness quetion HELP!!!)
Hi, I am swapping the h22a into my 4th gen prelude s, had problems on the wirings
done a lot of research, some said use the original s wire, but does it affect the ecu?
I got everything complete for the swap and i want to do it right.
any one please help out. Thank you so much!!!!
Old Dec 14, 2005 | 03:36 PM
red92s's Avatar
If your H22 is a JDM version, the engine wiring harness is worthless to you except for a few plugs and you will need to reuse your F22 harness. If your H22 is a USDM version and the engine wiring harness is complete and in-tact, then you can use it.
If you end up using the F22 harness, you will need to add wiring for the knock sensor, IAB's, VTEC equipment. Also, you will need to rewire the distributor for use with an external coil, and likely need to extend the O2 sensor wiring.
Old Dec 14, 2005 | 05:12 PM
prelude72569858's Avatar
Default Re: (red92s)
why is the JDM harness useless? because the plugs are on the other side??
Old Dec 14, 2005 | 05:36 PM
SteveoBA8's Avatar
Default Re: (prelude72569858)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude72569858 &raquo;</TD></TR><TR><TD CLASS="quote">why is the JDM harness useless? because the plugs are on the other side??
</TD></TR></TABLE>Yes, it was meant for the rhd chassis, it could be used if you want to extend alot of the wires. On Rhd preludes the ecu is on the other side, opposite of usdm cars.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jc8251123 &raquo;</TD></TR><TR><TD CLASS="quote">Hi, I am swapping the h22a into my 4th gen prelude s, had problems on the wirings
any one please help out. Thank you so much!!!!</TD></TR></TABLE>
Red92s is right, you need to wire the ks,iabs,vtec,extend o2 wiring and rewire if you use the jdm internal coil dizzy or you can use a usdm h23/h22 dizzy and it will plug in. If you do this you can re-use you f22a's external coil. As long as you use the right ecu you will be fine P13. Check out the faq's up top for an ecu harness pinout for the ks,iabs,vtec.
Old Dec 14, 2005 | 11:47 PM
jc8251123's Avatar
Default Re: (SteveoBA8)
Thank you for all the info
but do I need to rewire the harness in the car(connectors for the ecu?)
cause it looks like missing a couple connectors with the f22 harness
if any one could provide a diagram for the engine wire harness that could save my day
Old Dec 15, 2005 | 05:31 AM
ThE PiMpiN Co's Avatar
Default Re: (jc8251123)
It should work fine. The only wires I can think of that are not on an F22 but are on an H22 are the 3 wires/plugs for VTEC. Other than that, they should all be there...
Old Dec 15, 2005 | 09:08 AM
jc8251123's Avatar
Default Re: (aRaBiAn RiCe)
thank you for your info
but does any one know where i can find pictures of the wire that i should wire for the vtec valves.
and i should get a usdm distributor or rewire it thank you
Old Dec 15, 2005 | 09:25 AM
SteveoBA8's Avatar
all you need is the actuall ecu pins( you can get these at a salvage yard) check out the how to wire vtec in the prelude FAQ's up top. Its up to you if you want to use the external coil dizzy, if yo do i think it should plug right into the f22's engine harness. i used an h23 engine harness but the connectors should be the same.
Old Dec 15, 2005 | 09:41 AM
Look in the Essential Prelude Link at the top of the prelude forums, the whole process should be in there. Use your USDM Dizzy because it is better than the JDM internal coil dizzy.
Old Dec 15, 2005 | 11:17 AM
red92s's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aRaBiAn RiCe &raquo;</TD></TR><TR><TD CLASS="quote">Use your USDM Dizzy because it is better than the JDM internal coil dizzy.</TD></TR></TABLE>
The F22 distributor will not bolt to the H22 head (like the H23 one can).
Old Dec 15, 2005 | 11:58 AM
jc8251123's Avatar
can any one provide the link for how to wire the h22 thank you!
jc8251123's Avatar
and can I reuse the f22 coil??
Old Dec 15, 2005 | 01:14 PM
SteveoBA8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jc8251123 &raquo;</TD></TR><TR><TD CLASS="quote">can any one provide the link for how to wire the h22 thank you!</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=1004852 Dude look in the prelude FAQ'S!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jc8251123 &raquo;</TD></TR><TR><TD CLASS="quote">and can I reuse the f22 coil??</TD></TR></TABLE>
Yes
Old Dec 15, 2005 | 03:36 PM
red92s's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SteveoBA8 &raquo;</TD></TR><TR><TD CLASS="quote">
Yes</TD></TR></TABLE>
. . . The F22 coil is fine (as stated above), but it wont bolt up to the block without the a USDM coil bracket from an H23/H22.
Old Dec 15, 2005 | 05:38 PM
jc8251123's Avatar
thanks a lot on the vetec wiring info
but there are still a couple connectors missing
one under the oil filter (dealer call it oil pressure switch)
one for something like a air reservoir under the intake manifold.
and one above the fuel injectors.
and the last one is the knock sensor.
and i have 2 extra connector oxygen and water temp sensor. should i cut it?
and my ecu had 4 socket instead of 3.............
please help!! thank you all so much!!!
if any one can leave me their email i'll send the picture of the connectors thank you(i don't know why i can't put picture in here =.="
Old Dec 15, 2005 | 06:19 PM
SteveoBA8's Avatar
im betn your lude is a 96(obd2) ?
Old Dec 16, 2005 | 08:54 AM
jc8251123's Avatar
I think the maybe mine ecu is off an auto h22a..
would it still work for m/t
and does anyone know where to wire those connectors please
Old Dec 16, 2005 | 09:09 AM
SteveoBA8's Avatar
Im pretty sure the ecu plugs for obd1 and 2 are different, what year is your car? If this is the case then just get an adapter harness, pin it and your good to go.
The plugs are the same auto/manual ecu wise as long as they are both the same obd, i can email you a pic of my P12 f22a1 auto ecu so you can see the plugs, exactly the same as my p13 manual h22a.
Modified by SteveoBA8 at 10:25 AM 12/16/2005
Modified by SteveoBA8 at 10:36 AM 12/16/2005
Old Dec 16, 2005 | 11:39 AM
jc8251123's Avatar
HI i am trying to finish the wiring for engine and drop back in the car
please help on the engine oil pressure switch and the little valve on top of the fuel injectors
thank you so much!
Old Dec 16, 2005 | 12:42 PM
SteveoBA8's Avatar
You might need to extend the oil pressure wire(should be a single yellow and someother color wire with a ground type thing on the end) a little to reach the h22's sender. The faq's will show you how to wire the rest. WHAT YEAR IS YOUR CAR?
Old Dec 16, 2005 | 01:28 PM
jc8251123's Avatar
my car is a 92 prelude s f22
but i don't know what year is the front clip tho
so can i still use that auto h22 ecu on my m/t ?
thank you
Old Dec 16, 2005 | 01:50 PM
SteveoBA8's Avatar
You should get a manual ecu but it should start with the auto ecu.
So you bought a jdm prelude front clip? thats what i did too.
Old Dec 17, 2005 | 09:06 AM
jc8251123's Avatar
so u mean everything should be just fine with the auto ecu
and how difficult if i want to change the a/c control unit too
thank you. and the extra oxygen sensor is useless?? and a coolant temp sensor connector too
Old Dec 17, 2005 | 04:23 PM
red92s's Avatar
Something you may want to consider looking into:
http://rywire.com/store/produc...b7b4e
Old Dec 17, 2005 | 04:31 PM
SteveoBA8's Avatar
Good find Thats a good thing for people who dont want/know how to wire and use a multimeter. I made my own.
