Need help with ECU codes - Thanks
Old Dec 14, 2005 | 02:41 PM
Ehron's Avatar
Default Need help with ECU codes - Thanks
Hey guys. I need to get my emissions done, but I can't pass b/c my check engine light is on. The two codes are:
(I might be a letter or number off. The guy at autozone has barely legible scrawl)
P1259 - Manufacturing Cotrol - Fuel Air Metering
P0141 - 0-2 sensor Heater Circuit Malfuntion
I suspect the second one is due to a bad 02 sensor (the one in the cat). It is just a suspicion though. Anyone have any ideas? Thanks guys.
Old Dec 14, 2005 | 04:12 PM
SVOboy's Avatar
ECU? Engine? Type of o2 sensor (how many wires)?
Old Dec 14, 2005 | 04:55 PM
Ehron's Avatar
Default Re: (SVOboy)
Sorry, 99 Si. Not sure how many wires. Been a while since I have been under the car.
Old Dec 14, 2005 | 04:59 PM
SVOboy's Avatar
Oh blah, can't help you then, I dunno crap about obd2 ecus.
Old Dec 14, 2005 | 05:31 PM
drdisco69's Avatar
Default Re: Need help with ECU codes - Thanks (Ehron)
My turn! Fuel air metering = O2 sensor. I can't remember if that code is for primary or secondary sensor, but you've got a bad (or unplugged) O2 sensor.
Old May 5, 2006 | 06:20 PM
Ehron's Avatar
Default Re: Need help with ECU codes - Thanks (drdisco69)
Thanks all. In case anyone was curious it was the secondary O2 sensor.
vtec2nv
Apr 12, 2013 04:52 AM
blackcivic11
Aug 28, 2008 10:29 AM
skaternak
Jul 20, 2008 10:50 AM
iluvmy2000civicex
Apr 17, 2008 10:43 PM
longhair77
Jun 23, 2006 11:00 AM
