Throttle Position Sensor Wiring
Old Dec 14, 2005 | 12:39 PM
Combustion Contraption's Avatar
Default Throttle Position Sensor Wiring
Upon installing my latest mod, i was required to use a different type of throttle position sensor, so i had to splice in a new connector on the harness side. Simple enough. So i took a look at the wiring diagram and it seemed simple enough. Here is what i have to work with so far. This is a view of the new throttle position connector next to the stock honda wiring diagram.
So this is the way i figured it should be wired up.
Now, when i run the car at closed throttle hondalogger states im at 95% throttle, as i rev, the number drops in percentage. So basically, somethings backwards. But looking at the diagram i dont see what it could be. Any help is appreciated, thanks.
Old Dec 14, 2005 | 02:02 PM
SilCiv2K's Avatar
Default Re: Throttle Position Sensor Wiring (LsVtec92Hatch)
well based on your diagram it seems like you wired it correctly. im assuming your using a larger tb which came with its own tps already mounted. have you made sure the sensor itself is adjusted at the right angle. Use a DVOM , connect one probe to ground and the other one onto Input signal, you should adjust the tps so it reads .45V at CLOSED throttle and 4.5V at WOT.
Old Dec 14, 2005 | 02:06 PM
Right now, i measured it at the ECU, closed throttle is reading near reference voltage, 4.6v. As i depress the throttle, it drops to the 1.3v range. Its doing the opposite of what it should be doing.
If i switched the ground and the 5v reference would this be a symptom?
Old Dec 14, 2005 | 04:00 PM
Ok, well i dragged my *** outside and reversed the + and - wires and that was it. idles beautifully now.
Old Dec 14, 2005 | 04:02 PM
rainforest's Avatar
sounds like its reversed. it is just reading wot instead of referance voltage
Old Dec 14, 2005 | 04:04 PM
Read the post directly above yours rainforest.
TwoKSiR
Jun 14, 2008 11:06 AM
valentine97
19
Jan 15, 2008 10:33 AM
Dec 14, 2005 08:55 PM
