What is this called??
Old Dec 14, 2005 | 10:20 AM
EF_LEGOMAN's Avatar
Default What is this called??
Ok, so the my idle problem continues. Me and a friend of mine did some troubleshooting the other day. We ruled out the TPS sensor, TB, and the vacuum lines. It looks like THIS... may be the problem:
Anybody know what thats called? And where i may be able to find one?
THANKS!
Old Dec 14, 2005 | 10:23 AM
DaveSmed's Avatar
Default Re: What is this called?? (EF_LEGOMAN)
Looks like the MAP sensor.
Old Dec 14, 2005 | 10:29 AM
EF_LEGOMAN's Avatar
Default Re: What is this called?? (DaveSmed)
Thanks Dave. Is that entire thing the MAP sensor? Is that cylindrical piece (F in the picture) a different part?
Old Dec 14, 2005 | 10:31 AM
Suck my DX's Avatar
the whole thing is one unit
Old Dec 14, 2005 | 10:35 AM
EF_LEGOMAN's Avatar
Ok thanks guys. So im ebay right now looking around. Are map sensors OBD specific?? I see a couple from 92-95 civics and theres one off a JDM motor. Are they all compatible or must i get one from a OBD0 motor??
Thanks alot.
Old Dec 14, 2005 | 10:36 AM
Outsane's Avatar
Default Re: What is this called?? (Suck my DX)
F is a purge valve...for smog stuff..circulating fumes here are and there.
the sensor with the three wires that goes to it is your map sensor..
On OBD1 cars its mounted on the TB..
Old Dec 14, 2005 | 10:38 AM
EF_LEGOMAN's Avatar
Default Re: What is this called?? (Outsane)
ahhh i see! Thank you Outsane. But will it still work on a OBD0 motor?
Old Dec 14, 2005 | 10:40 AM
2nxcrx's Avatar
I have an extra obd-0 map sensor laying on my desk if you're interested. PM me.
Old Dec 14, 2005 | 10:46 AM
EF_LEGOMAN's Avatar
Default Re: (2nxcrx)
how the heck do I PM someone on here?? I see IM, is that what you meant. Well anyway... I could use that MAP sensor. Where are you located 2NXCRX?
Old Dec 14, 2005 | 11:15 AM
Boosted Chemist's Avatar
Default Re: (EF_LEGOMAN)
you could get a obd1 senson and make it work, if you considering turbo in the future i would geta motoralo 2.5 bar or gm 3 bar now. (if you ecu supports different map sensors)
Old Dec 14, 2005 | 12:08 PM
2nxcrx's Avatar
Hey I got your IM and responded you can email me as well if that's easier. mulder65@comcast.net
menappi
Jul 2, 2006 06:31 PM
BoRiCuA
Jun 30, 2004 06:06 AM
HondaCutter
Sep 23, 2002 09:41 AM
