Why does EuDM 5gen H22 Lude have 0.7 sec higher 0-60mph time that USDM
Old Dec 14, 2005 | 08:29 AM
PreludEst's Avatar
Default Why does EuDM 5gen H22 Lude have 0.7 sec higher 0-60mph time that USDM
Until today I was thinking that it was mainly beacuse of the final drive, as I thought that H22 euro ludes had 4.06 FD. However, today I used the Speed/RPM calculator to check that and it turns out that I also have 4.266 FD. So now I am totally confused why do EuDM and USDM 5g H22 Ludes have such a big difference in acceleration, as the only difference between them that I know of is that EuDM has 185 crank HP and USDM has something like 195.
Can someone please enlighten me if 10 hp advantage can translate into such difference in acceleration or it there something else?
TIA
Old Dec 14, 2005 | 08:47 AM
The_Sober's Avatar
Default Re: Why does EuDM 5gen H22 Lude have 0.7 sec higher 0-60mph time that USDM (PreludEst)
maybe that's metric 0.7 sec...
just kidding. probably either a worse driver, or emissions makes the hp lower
Old Dec 14, 2005 | 08:55 AM
PreludEst's Avatar
Default Re: Why does EuDM 5gen H22 Lude have 0.7 sec higher 0-60mph time that USDM (The_Sober)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The_Sober &raquo;</TD></TR><TR><TD CLASS="quote">maybe that's metric 0.7 sec...
just kidding. probably either a worse driver, or emissions makes the hp lower</TD></TR></TABLE>
I guess the driver skills should be pretty much the same, as these are official figures. I have actually got ~7.0 on mine, but it has I/H/E.
The difference in power is only 10 HP. Can it be that much quicker with only 10 hp more ?
Old Dec 14, 2005 | 09:47 AM
pentaq's Avatar
Mind they show 0-60mph in USA and 0-100kph in Europe.
60mph&lt;100kph
usually you can reach 100kph changing the gear and it takes time.
Old Dec 14, 2005 | 10:02 AM
PreludEst's Avatar
Default Re: Why does EuDM 5gen H22 Lude have 0.7 sec higher 0-60mph time that USDM (pentaq)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pentaq &raquo;</TD></TR><TR><TD CLASS="quote">Mind they show 0-60mph in USA and 0-100kph in Europe.
60mph&lt;100kph
usually you can reach 100kph changing the gear and it takes time.</TD></TR></TABLE>
Hm... That might really be the reason. Although 60mph is 96 kmh, if it still requires to change gear to reach 100, then it explains the difference. (I'll have to check at what kmh my 2nd gear tops out - I'm 90% sure its exactly 100kmh).
Old Dec 14, 2005 | 12:25 PM
The_Sober's Avatar
yeah, 100kmh is 63mph...
Old Dec 14, 2005 | 12:35 PM
A Blue Lude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The_Sober &raquo;</TD></TR><TR><TD CLASS="quote">yeah, 100kmh is 63mph...</TD></TR></TABLE>
62
Old Dec 14, 2005 | 01:54 PM
PreludEst's Avatar
Default Re: Why does EuDM 5gen H22 Lude have 0.7 sec higher 0-60mph time that USDM (Featherfire)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Featherfire &raquo;</TD></TR><TR><TD CLASS="quote">
62</TD></TR></TABLE>
Then, according to the calculator I should be at 62mph=100kmh at 8000 rpm in 2nd gear. So, it seems that you don't need to shift to third to reach 100kmh.
Old Dec 14, 2005 | 03:40 PM
red92s's Avatar
Elevation?
Road conditions?
Drivers?
Weather?
Add'l fancy-pants non-USDM equipment?
. . . not really a fair comparison.
Old Dec 14, 2005 | 07:00 PM
v4lu3s's Avatar
RTFM
what stock prelude is able to go past the rev limiter to shift at 8k rpm?
Old Dec 15, 2005 | 02:20 AM
pentaq's Avatar
Default Re: (v4lu3s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s &raquo;</TD></TR><TR><TD CLASS="quote">what stock prelude is able to go past the rev limiter to shift at 8k rpm?</TD></TR></TABLE>
good point, I just wanted to mention this.
Old Dec 15, 2005 | 04:09 AM
PreludEst's Avatar
Default Re: (pentaq)
good point, I just wanted to mention this.</TD></TR></TABLE>
That is definately a good point. However, I'm pretty sure that I can reach 100kmp (at least on the speedo) in the 2nd gear. I guess I will have to check it today, when going home from work .
Old Dec 15, 2005 | 01:04 PM
PreludEst's Avatar
Default Re: (PreludEst)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PreludEst &raquo;</TD></TR><TR><TD CLASS="quote">
That is definately a good point. However, I'm pretty sure that I can reach 100kmp (at least on the speedo) in the 2nd gear. I guess I will have to check it today, when going home from work .</TD></TR></TABLE>
Ok, I checked it today, and I can easily get quite a bit over 100 kmh in 2nd gear (~107). So the difference is not because of shifting.
Old Dec 15, 2005 | 06:57 PM
v4lu3s's Avatar
RTFM
sounds like long *** gears in the tranny then to me, unless you got a chip or higher rev limit.
Old Dec 15, 2005 | 11:23 PM
PreludEst's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s &raquo;</TD></TR><TR><TD CLASS="quote">sounds like long *** gears in the tranny then to me, unless you got a chip or higher rev limit.</TD></TR></TABLE>
No I have a bone stock ECU, and the tranny is more or less the same as USDM one. I was already above 100 at 7500 rpm. The only thing I could think of is that maybe the speedo is that much off
Old Dec 16, 2005 | 05:40 AM
Honda318dx's Avatar
This is pointless.. Do you realize how unaccurate the tachs and speedos are in these cars?
twiztid00002
Feb 18, 2009 04:48 AM
Sleeping_H22_DC2
Mar 7, 2006 09:42 PM
driftinflyboy
Feb 3, 2006 02:10 PM
H22a4DarkHatch
Apr 25, 2005 07:47 AM
BoOstInHaRd
Mar 26, 2005 12:44 PM
