obd 1 b18a in 91 Civic Dx... Quick Help
Old Dec 14, 2005 | 12:24 AM
Nisif's Avatar
Default obd 1 b18a in 91 Civic Dx... Quick Help
Unfortunately the 90 b18a motor I bought from the yard is fucked, almost 95% leakdown at tdc, so I'm taking it back. If I end up with a 92-93 ls motor instead I'd like to know what I'll need to do in order to run as obd 0. I have searched, so plz don't flame, links are appreciated. I have a pr4 (obd 0) ecu, dizzy, and injectors which will be used on the 92-93 motor if I end up buying that year motor. Anything else I need, or that I should be aware of, obviously will be doing the dpfi to mpfi conversion, but I'm concerned about any extra **** I'll have to do if I end up with a obd 1 motor. Will the obd 1 engine harness work will the application? Thanks, any input or suggestions (links) are appreciated
Old Dec 14, 2005 | 12:38 AM
crxnj's Avatar
Default Re: obd 1 b18a in 91 Civic Dx... Quick Help (Nisif)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nisif &raquo;</TD></TR><TR><TD CLASS="quote">I have a pr4 (obd 0) ecu, dizzy, and injectors which will be used on the 92-93 motor if I end up buying that year motor.</TD></TR></TABLE>
Thats exactly what you need..Dont use the obd1 integra harness at all..Use your stock harness converted to mpfi and your done..Also you can use the obd1 injectors ,,just don't run a resistor box since they're saturated..The only thing Im not sure on is the 02 sensor..I think you have to get a 88-91 style o2 sensor if you run pre obd..Because the 92-95 sensor is 4 wire heated..
Old Dec 14, 2005 | 12:57 AM
Rywire's Avatar
Default Re: obd 1 b18a in 91 Civic Dx... Quick Help (Mr.speaker)
Hes right, For sure dont use the integ harness, just use it for parts for the mpfi swap.
Old Dec 14, 2005 | 10:44 AM
Nisif's Avatar
Default Re: obd 1 b18a in 91 Civic Dx... Quick Help (droppedcrxsi)
Thanks guys
pmpm06
Jan 2, 2008 10:13 AM
pmpm06
Dec 28, 2007 07:29 PM
dephtone
10
Jan 2, 2007 04:44 PM
Lsgsr94
Dec 26, 2006 11:17 AM
crampinyourstyle
Aug 6, 2006 03:28 AM
