what is the cheapest deal on a built motor
Old Dec 13, 2005 | 08:58 PM
23snorub's Avatar
Default what is the cheapest deal on a built motor
full listiing of where????
Old Dec 13, 2005 | 09:00 PM
BrooX's Avatar
Default Re: what is the cheapest deal on a built motor (23snorub)
You wanna go fast, you can't go cheap. Especially with honda's
Old Dec 14, 2005 | 12:58 AM
Deluzional's Avatar
Default Re: what is the cheapest deal on a built motor (DA9GUY-637)
Id check the classifieds
Old Dec 14, 2005 | 09:46 AM
fergy016's Avatar
Just becareful you only get two of the three options:
Cheap
Reliable
Fast
Old Dec 14, 2005 | 10:08 AM
adseguy's Avatar
Default Re: (fergy016)
what do you mean by built?? You can get just forged pistons and forged rods to get 500whp with a turbo setup. But then you need everythig else like new headgasket, water pump, oil pump, head studs, bearings, and anything else required in a proper engine build. All OEM, but new none the less. After that you probably want to get it sleeved. In the sponsers forum I see eagle rods and CP pistons go for $850 shipped so add another $400 for random things like the oil pump etc and there you go built bottom end . Then estimate how much for someone to build it for you if you can't.
Are you talking about the head or bottom end or both?
Old Dec 14, 2005 | 10:13 AM
xplanetearth420x's Avatar
i wouldnt say the word cheap when builting a motor they dont go together trust me
but what are your goals for the motor?is it gonna stay all motor,are you gonna boost?
do u want 200whp,300whp there is so many different things you do to a motor depending on what u want the end result to be
Old Dec 14, 2005 | 08:30 PM
23snorub's Avatar
Default Re: (adseguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy &raquo;</TD></TR><TR><TD CLASS="quote">what do you mean by built?? You can get just forged pistons and forged rods to get 500whp with a turbo setup. But then you need everythig else like new headgasket, water pump, oil pump, head studs, bearings, and anything else required in a proper engine build. All OEM, but new none the less. After that you probably want to get it sleeved. In the sponsers forum I see eagle rods and CP pistons go for $850 shipped so add another $400 for random things like the oil pump etc and there you go built bottom end . Then estimate how much for someone to build it for you if you can't.
Are you talking about the head or bottom end or both?</TD></TR></TABLE>
im talkin bout bottom end
hondacrx2
Mar 28, 2011 09:10 PM
RPRacing
Oct 23, 2008 03:15 AM
spraa
Dec 29, 2003 05:57 PM
99integralsturbo
Oct 31, 2003 07:07 AM
GreddySi99
Sep 27, 2003 06:44 AM
