is it worth putting a h22 in a 89 civic si?
Old Dec 13, 2005 | 07:58 PM
89civich22's Avatar
Default is it worth putting a h22 in a 89 civic si?
Old Dec 13, 2005 | 08:05 PM
1RMDave's Avatar
ok, i'm glad i got to this before you got flamed bad. First do a search its been covered lots. and second if you are serious about it check out the bisimoto adapter plate to mount the h22 on a d series tranny, it'll mmake ur life happier
Old Dec 14, 2005 | 12:01 AM
StorminMatt's Avatar
Default Re: (1RMDave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1RMDave &raquo;</TD></TR><TR><TD CLASS="quote">check out the bisimoto adapter plate to mount the h22 on a d series tranny, it'll mmake ur life happier</TD></TR></TABLE>
I personally would go with a B-series transmission rather than a D-series transmission. The H22A puts out quite a bit of torque. And the MUCH beefier B-series transmission and axles are going to stand up to it MUCH better. D-series transmissions are just weak. They don't even stand up really well to boosted D-series motors. And the unequal length axles are just asking for torque steer. All this means that an H2B adaptor is a MUCH better way to go.
Old Dec 14, 2005 | 09:47 AM
1RMDave's Avatar
the cable b series trans is no better than a d series strength wise. Besides if you're anything like me you have 2 or 3 d series trannys laying around. With the money you save not having to buy a b series mount kit, axles, shift linkage and tranny you can buy an LSD and take care of alot of that torque steer.
Old Dec 14, 2005 | 10:28 AM
CarAudioPro's Avatar
drag only, that motor is to heavy to do auto x.
Old Dec 14, 2005 | 12:19 PM
CRX Toad's Avatar
Default Re: is it worth putting a h22 in a 89 civic si? (89civich22)
If you can't do the work to put the H22 in (ie. the welding, cutting and fabrication.) Then a B-series or D-series is going to be your best bet.
Old Dec 14, 2005 | 12:25 PM
1RMDave's Avatar
the motor isn't too heavy, the bulk of the extra weight comes from using the h22 tranny. If you use a d or b series trans then i bet its not much heavier than a b series swap.
Old Dec 14, 2005 | 12:47 PM
ExplicitSpeed360's Avatar
Banned.
Please visit my site goes into full detail on the H22 EF swap. It is not that hard! it was my 2nd swap! My H22 crx weighs in at 2020 without me in it... it could be ligther then a gsr swap? Skunked weighed in transmissions H series weighed 2-3 lbs more then a GSR transmission. Weight is not a problem. Mine corners better then my LS crx did. It's a great swap and I wouldn't change it. 158 ft lb torque at 3200 rpm is one hell of a nice feeling.
Old Dec 14, 2005 | 03:36 PM
Chris Styles's Avatar
The H22 is a horrible engine for all tha EF's. The H22 belongs to tha prelude. If u put an H22 into a EF it will throw off all tha weight of the vehicle. Don't get me wrong tha H22 is a superior engine... But its not desingned for the EF's... If u did get it that means you would have to customize the chasis of ur civic... Which will cost u a lot. Plus any type of mount will snap if ur goin to be street racing... There will be too much weight in the front meaning it will weigh u down... The H22 only has about 180 to 190 HP to the wheel... Which is a lot... But you will find better results havin a B16A1 or a B18C1 W/ a GsR Tranny... Good Luck if u decide gettin tha H22 Motor...
-Chris Styles
Old Dec 14, 2005 | 03:50 PM
Suck my DX's Avatar
Default Re: is it worth putting a h22 in a 89 civic si? (Chris Styles)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris Styles &raquo;</TD></TR><TR><TD CLASS="quote">The H22 is a horrible engine for all tha EF's. The H22 belongs to tha prelude. If u put an H22 into a EF it will throw off all tha weight of the vehicle. Don't get me wrong tha H22 is a superior engine... But its not desingned for the EF's... If u did get it that means you would have to customize the chasis of ur civic... Which will cost u a lot. Plus any type of mount will snap if ur goin to be street racing... There will be too much weight in the front meaning it will weigh u down... The H22 only has about 180 to 190 HP to the wheel... Which is a lot... But you will find better results havin a B16A1 or a B18C1 W/ a GsR Tranny... Good Luck if u decide gettin tha H22 Motor...
-Chris Styles</TD></TR></TABLE> u obviously have no idea what ur talking about...once u drive an h22 ef then u might understand why this swap is so desirable...it just rips anyother swap out of the water...the only other i think may stand a chance is the f20c swap
Old Dec 14, 2005 | 05:02 PM
Banned.
Default Re: is it worth putting a h22 in a 89 civic si? (Suck my DX)
anyone who has ever been skeptical of my H22 crx gets in my car and by the time I let them out is already trying to contact a loan officer for a loan to start the project
Old Dec 14, 2005 | 08:49 PM
1RMDave's Avatar
please stfu and read the posts
Old Dec 14, 2005 | 08:56 PM
Hamstr323's Avatar
I wonder why your a trial user???? moron don't post dumb sh*T if you don't know what your talking about
M1SCO15
Jun 5, 2007 11:56 AM
ferton2003
10
Feb 21, 2007 08:05 AM
msinsky14
Feb 24, 2006 06:29 PM
B SERIES US
Oct 28, 2004 10:52 AM
ah789454
Jul 26, 2004 09:39 PM
