K20a2 head on K20a3 block
I searched but it seems that the keywords Im using are too short and I got no where.
Anyway... Im looking for info on the swap. Its going into a 02 SI w/ K-pro already. Thanks for any info
http://www.ephatch.com/forum i believe there is more info over there than on here about this swap...hth
More ephatch'ers have done the head swap, but I don't think many people have done it in quite a while.
That's because there's just not a lot to gain with just swapping the head. You'll get better breathing with the high cam, but you won't have the A2's higher compression, and you won't have the oil squirters and whatnot that's included in the A2 block.
The consensus these days is that a motor swap produces a better result than just a head swap, and the effort involved is about the same.
I'll bet that k20a.org has a bunch of info, too. I'd dig around there.
i want know if it is possible to fit a Acura RSX K20 into A 92-95 Honda Civic If so please reply at Babyluvalle@aol.com
tunerguy0985
Sep 7, 2011 02:51 PM
integral94
Jun 2, 2004 08:33 PM
