how thick should the piping be for a turbo manifold??
Old Dec 13, 2005 | 07:00 PM
hatchinprogress's Avatar
Default how thick should the piping be for a turbo manifold??
a friend of mine is gonna make a turbo mani for me, so i went and bought the piping for it but he says he thinks it's too thin ( looks a lil bigger then 1/8th thick) so how thick should the piping be to hold up to the high temp.????
Old Dec 13, 2005 | 07:08 PM
*Boostwerks*'s Avatar
Sch 10, and 40 seem to stand up to most abuse. Of course there are hundreds of other factors, that will determine the durability of a manifold.
Old Dec 14, 2005 | 04:32 AM
Default Re: (Bryson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryson &raquo;</TD></TR><TR><TD CLASS="quote">Sch 10, and 40 seem to stand up to most abuse. Of course there are hundreds of other factors, that will determine the durability of a manifold. </TD></TR></TABLE> im not sure if its sch10 or 40...how could i find that out? and how thick does it need to be to hold up to the high heat?
Old Dec 14, 2005 | 09:58 AM
AceRaceParts's Avatar
Default Re: (hatchinprogress)
Here are the measurements of both schedules:
1.5" s/10 = 1.9" OD x .109" wall = 1.682" ID
1.5" s/40 = 1.9" OD x .145" wall = 1.610" ID
Old Dec 14, 2005 | 11:02 AM
weiRtech's Avatar
OG Fabricator
my current manifold is schedule 10 304ss. my new manifold is going to be 16guage ms.
Old Dec 14, 2005 | 04:02 PM
TrueNorthStar's Avatar
Default Re: (weirRacing)
16ga on mine... You need to have a mount/brace for your turbo so you dont put any weight on the manifold.
Old Dec 14, 2005 | 06:09 PM
Default Re: (mbpwrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mbpwrx &raquo;</TD></TR><TR><TD CLASS="quote">Here are the measurements of both schedules:
1.5" s/40 = 1.9" OD x .145" wall = 1.610" ID</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by weirRacing &raquo;</TD></TR><TR><TD CLASS="quote">my current manifold is schedule 10 304ss. my new manifold is going to be 16guage ms.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TrueNorthStar &raquo;</TD></TR><TR><TD CLASS="quote">16ga on mine... You need to have a mount/brace for your turbo so you dont put any weight on the manifold.</TD></TR></TABLE> im sorry guys i guess i dont understand all this if i had piping that is 1/16th to 1/8th thick would it hold up to the heat and weight(if i make a support bracket)??
Old Dec 16, 2005 | 01:46 PM
LeGeND4LiFe's Avatar
Why are you going from ss to ms?
Old Jan 11, 2006 | 09:03 PM
supercreed2002's Avatar
Default Re: (LeGeND4LiFe)
I'm sorry to bring an old post from the dead, but would 14ga MS pipes work too? And what knd of brace are you talking bout?
Old Jan 15, 2006 | 11:12 AM
Default Re: (supercreed2002)
would 16ga not hold the weight on itself without any brace/brackets...
Old Jan 15, 2006 | 03:32 PM
k24em2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by supercreed2002 &raquo;</TD></TR><TR><TD CLASS="quote">would 16ga not hold the weight on itself without any brace/brackets...</TD></TR></TABLE>
It might support the weight of the turbo when you build it, but once you get it hot it will have a tendancy to crack.
Old Jan 15, 2006 | 05:02 PM
ManBearPig4silly's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LeGeND4LiFe &raquo;</TD></TR><TR><TD CLASS="quote">
Why are you going from ss to ms?</TD></TR></TABLE>
good question.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by supercreed2002 &raquo;</TD></TR><TR><TD CLASS="quote">I'm sorry to bring an old post from the dead, but would 14ga MS pipes work too? And what knd of brace are you talking bout?</TD></TR></TABLE>
I wouldnt really use them but I suppose you could. Mild steel is not going to hold up to the extreme heat as well as stainless so it might have a shorter life span than expected. The braces mentioned are built to support the entire weight of the turbo so the manifold is bearing little to no weight.
Old Jan 15, 2006 | 09:53 PM
Default Re: (I4sillypwr)
Ok, so if I build a MD mani, how would you brace it up to keep from cracking?
Old Jan 15, 2006 | 10:33 PM
If I make an MS mani, what kind of brace/bracket would I need? And pics for an example?
Old Jan 16, 2006 | 12:14 AM
k24em2's Avatar
Old Jan 16, 2006 | 12:17 AM
Default Re: (k24em2)
What about on a Honda application? Seems like too much trouble....
Old Jan 16, 2006 | 12:26 AM
k24em2's Avatar
Same priciple.
Old Jan 16, 2006 | 06:56 AM
FastCougar's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by supercreed2002 &raquo;</TD></TR><TR><TD CLASS="quote">Seems like too much trouble....</TD></TR></TABLE>You know what they say: An ounce of prevention is worth a pound of cure. Spend a few hours now in the preliminary design phase to account for possible future problems, or spend MANY more hours developing a new manifold when this one cracks due to stress ... it's your call.
Old Jan 16, 2006 | 08:55 AM
Default Re: (FastCougar)
What about making a bracket off the ms exhaust flange to the turbo flange?? That seem like it would work...
Old Jan 16, 2006 | 10:37 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by supercreed2002 &raquo;</TD></TR><TR><TD CLASS="quote">What about making a bracket off the ms exhaust flange to the turbo flange?? That seem like it would work...</TD></TR></TABLE>
ever seen an ssautoshitmanifold? Doesnt seem to work to well. triangles own you.
Old Jan 16, 2006 | 02:57 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I4sillypwr &raquo;</TD></TR><TR><TD CLASS="quote">ever seen an ssautoshitmanifold? Doesnt seem to work to well. triangles own you. </TD></TR></TABLE>
No man...I'm not talking about sheet metal, I'm talking those bar looking things as in the following pics...
Old Jan 16, 2006 | 03:58 PM
weiRtech's Avatar
OG Fabricator
it is going to be ceramic coated so i want to keep it all the same material. ms is also cheaper. 16g has a side wall thickness of .063"
Old Jan 16, 2006 | 04:08 PM
Default Re: (weiRtech)
Oh man I'm confused about what you are talking about now......I was talking about the bar welded between the turbo and head flanges on a ssatuoshit. Bracing to the body of the turbo would be better.
Old Jan 16, 2006 | 04:17 PM
The exhaust and turbo flanges will be .5" thick....I was seeing if you can make a bar to hold these two flanges together in a certain way so they can support the weight of the turbo so I can get away with MS 16ga pipes and flange.
criitter7
Welding / Fabrication
Mar 13, 2007 09:39 AM
OrangeBoost
10
Nov 17, 2005 01:53 PM
Cain Marko
Sep 7, 2004 12:40 PM
95hybridcivic
Jan 30, 2003 01:25 PM
veejay
Sep 5, 2001 07:49 PM
