Both Tires Spin?
Old Dec 13, 2005 | 05:25 PM
93Ludevtech's Avatar
Default Both Tires Spin?
Hey...I have got a question...it might sound dumb but I need to know if the front wheels are supposed to spin together? For example...I have the car jacked up and I would spin one wheel but the other is not moving...and the other side is really hard to spin...is this right or do i have a problem? I just changed the outer boot also. And yes, they both are off the ground. Thanks.
Old Dec 13, 2005 | 05:36 PM
Default Re: Both Tires Spin? (93Ludevtech)
anyone.....help?
Old Dec 13, 2005 | 05:47 PM
precord96's Avatar
That's normal. If you had a LSD then both would turn together.
Old Dec 13, 2005 | 05:48 PM
SteveoBA8's Avatar
Default Re: Both Tires Spin? (precord96)
another 4th gen in kansas eh
thanks alot...i was worried for a bit.
Old Dec 13, 2005 | 08:45 PM
K-Spec's Avatar
they both should spin with LSD or not. However, if you have LSD they spin the same direction as opposed to opposite.
Old Dec 13, 2005 | 08:48 PM
roller3804's Avatar
Default Re: Both Tires Spin? (khalal538)
I was under the impression that LSD just gives the most power to the wheel with the most traction and open diff gives power to less traction wheel??
when would the wheels turn opposite directions??
Old Dec 13, 2005 | 09:13 PM
Default Re: Both Tires Spin? (camrann)
ok guys....so they both should spin even if i turn one wheel...or should the driver side stay still while i am turning the passenger wheel?
Old Dec 13, 2005 | 11:22 PM
Jake_Sale's Avatar
Lsd Mate
Old Dec 14, 2005 | 02:18 AM
K-Spec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by camrann &raquo;</TD></TR><TR><TD CLASS="quote">I was under the impression that LSD just gives the most power to the wheel with the most traction and open diff gives power to less traction wheel??
when would the wheels turn opposite directions??</TD></TR></TABLE>
when your car is off and hiked up on jackstands, you rotate the tires with your hands and have a friend watch the other wheel
Old Dec 14, 2005 | 06:09 AM
iLude's Avatar
HowStuffWorks can explain to you have differentials work.
Or get one of those F1 Lego cars. It's got a open differential in it, so you can see how the gears work. No joke, it's actually pretty neat.
Old Dec 14, 2005 | 09:35 AM
SteveoBA8's Avatar
Default Re: Both Tires Spin? (iLude)
open diff- will send power to the wheel with the least resistance
Old Dec 14, 2005 | 11:49 AM
Silent Sam's Avatar
Guys he's not asking how to make them both spin or how an LSD works.
Old Dec 14, 2005 | 12:00 PM
BergRacing21's Avatar
Default Re: (Silent Sam)
NON-LSD-- one wheels spins in one direction the other spins in opposite
LSD-- BOTH wheels spin in the same direction
for your ??? i have no clue why your other wheel wouldn't be spinning unless and axle is broke or the hub is locked or something really weird that i dunno. lol both wheels should spin whether together or opposite directions tho.
Old Dec 14, 2005 | 12:04 PM
limpmode's Avatar
Default Re: (BergRacing21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iLude &raquo;</TD></TR><TR><TD CLASS="quote">HowStuffWorks can explain to you have differentials work.
Or get one of those F1 Lego cars. It's got a open differential in it, so you can see how the gears work. No joke, it's actually pretty neat.</TD></TR></TABLE>
HowStuffWorks=
and my brother had that lego F1 set, it was pretty cool.
Old Dec 14, 2005 | 02:18 PM
how does ones hub get locked? b/c the driver side is really hard to spin but the passenger side is really easy to spin... any more inputs....thanks.
Old Dec 14, 2005 | 06:16 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93Ludevtech &raquo;</TD></TR><TR><TD CLASS="quote"> For example...I have the car jacked up and I would spin one wheel but the other is not moving....</TD></TR></TABLE>
i might of got the assumption from that... still i followed myself up by sayin something really weird who knows, it def. doesn't sound normal
Old Dec 14, 2005 | 09:21 PM
Default Re: Both Tires Spin? (BergRacing21)
could i have a broken axle?...that wouldn't make any sense b/c it worked fine until i had to fix replace the wheel stud on the other side. What could be the problem??? i also tried driving it on jack stands and the passenger side turns but not the driver side....sny help would be greatly appreciated...thank you guys.
Old Dec 14, 2005 | 09:29 PM
SteveoBA8's Avatar
put that **** on the ground and drive it them you will know if anythings fucked up, and yes its ok that only one wheel turns when on jack stands , remember open diff= power goes to wheel with the least resistance.
Old Dec 14, 2005 | 09:48 PM
Default Re: Both Tires Spin? (SteveoBA8)
thanks steveo, just didn't wanna be callin a tow truck to get my car thats all...u understand....rite.lol...but sreiously..i'll do that..so i can quit worryin about it. thanks.
Old Dec 14, 2005 | 09:50 PM
SteveoBA8's Avatar
i know how you feel about not wanting to break ****
Old Dec 14, 2005 | 09:58 PM
raylude's Avatar
From: united states of mexico and yes ladies i am, available
make sure your caliper isnt locked up holding the wheel in place if not then yeah its brobly your hub or axle or something
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by camrann &raquo;</TD></TR><TR><TD CLASS="quote">when would the wheels turn opposite directions??</TD></TR></TABLE>
they wont when your on the road driving thats just what normal open diffs do when you take both wheels off the ground
Old Dec 14, 2005 | 10:03 PM
Default Re: Both Tires Spin? (raylude)
how can i check the caliper???? and hub also???
Old Dec 15, 2005 | 05:09 AM
limpmode's Avatar
i think a question to be asked here is when you say it's on jack stands and only one wheel spins, do you mean you have the car running and in gear and only one will spin? if so you are ok, open diffs do that. if you have the car on stands, not running, in neutral and you spin one wheel by hand then they should spin opposite directions. I'm not a 4th gen expert but i'm pretty sure if you have a stock tranny on a USDM 4th gen, you do not have an LSD, you have an open diff.
if you have it on stands and you spin one by hand in neutral and one does nothing, then you have a problem. have you driven it at all? anything like broken axle, hub, ect, would be noticeable.
Old Dec 15, 2005 | 09:42 AM
Default Re: Both Tires Spin? (limpmode)
what would happen if the car was in gear and i manually turn the wheel(while on jack stand and car not running).....this would mess something up rite? Damn!
