need a bit of help
aight guys here's the deal i've got a fully built ls/vtec teg. motor is 100% sound. after rebuild ran perfect for 3 days 200 miles with no rpm time spent over 4300 rpms. 4th day came out car would not stay running, isolated that the only thing i didnt change were the clutch and flywheel so i went ahead and tested and sure enough on jack stands the car would run until you depressed the clutch and then would sputter and die. after the clutch change i started it up and it ran fine for about 5 mins and then the same thing. i checked every connection i can think of and they are all fine. perfect pin fit and everything. as for a list of mods to help in the diagnosis process here goes.
99 ls block bored to 82mm
eagle h beam connecting rods
jun 12/1 comp. pistons
king bearing and rings
arp head studs
jegs 82mm ls/vtec headgasket
01 ITR head w/ported exhaust ports
ferrea 1mm oversized valves
dual ferrea valve springs
buddy club spec 3 cams
inline pro gears
spoon 70mm throttle body
hondata s100
rc 310 injectors
walbro 255lph fuel pump.
competion clutch stage 2
stock gsr flywheel
ITR trans with quaife
intake
apexi 2 1/2 inch header and collector
cats.com 2 1/2 custom cat
stock JDM itr 2 1/2 inch exhaust
i am a three year gold level certified honda tech and i am utterly stumped i have check everything i know or could think of. any ideas would be greatly appreciated. thanks in advance
arp head studs
inline pro gears
hondata s100
rc 310 injectors
stock gsr flywheel
intake
it starts and runs perfectly, like any car should after 2 mins it starts to bog out and stall. try to keep it running with the throttle body or accelerator and the motor fights the attempted increase in rpms and still stalls. but will restart and run the exact same every single time. a somewhat confusing thing because i dont know of a single sensor that would cause something like this. any ideas are greatly appreciated. thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc r-spec »</TD></TR><TR><TD CLASS="quote">it starts and runs perfectly, like any car should after 2 mins it starts to bog out and stall. try to keep it running with the throttle body or accelerator and the motor fights the attempted increase in rpms and still stalls. but will restart and run the exact same every single time. a somewhat confusing thing because i dont know of a single sensor that would cause something like this. any ideas are greatly appreciated. thanks</TD></TR></TABLE>
i know of two sensors that would cause this 1.MAP sensor 2.TPS
also,make sure you have the right plugs connected to the right sensors...
it's probaly something with the distributor, i recently jus did a lsvtec swap and had the same problem....i change cap, rotors and spark plug wires and had no more troble....but i could be wrong too.....
thanks for the suggestions i will be trying them tonight and getting back to you but i do know one thing. the distributor is not the problem i changed out the distributor already with a complete unit and it did nothing. keep the idea coming
2n-chilli
11
Apr 15, 2011 07:35 AM
bloxp1vtec19
Jul 13, 2007 08:34 PM
JGC5INTEGRA
Feb 27, 2004 06:55 PM
