Si tranny on a Hf motor will it work
is it possible? I have the matching flywheel and clutch but I was wondering if hf axles will fit in the Si tranny also to make it work what else would I need any help would be great
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tangerinebeast »</TD></TR><TR><TD CLASS="quote">hf axles are smaller spline than si in order to do this you will have to swap out the hubs for a 5 speed dx hubs or si hubs crx hf and std hatch have smaller spline hubs</TD></TR></TABLE>NO, you will not!!!
the ONLY difference is the outer splines...aka: the hubs. the inner splines are the SAME. therefore, you CAN use the HF axles, they will spline correctly with the tranny and the hubs. the only problem with them is that they are tiny, but since he is using the HF motor, he wont have a problem
thanks thought they were smaller in and out wouldnt be a bad upgrade then since he is down there if money permits then he wouldnt have to do so down the road if he went with b-series etc.
wouldnt be a bad upgrade then since he is down there if money permits then he wouldnt have to do so down the road if he went with b-series etc. </TD></TR></TABLE>true, cant go wrong with new axles. if you buy the NAPA "new" not reman, they have a lifetime warranty. ive already replaced one of mine because the boot tore
thanks thought they were smaller in and out wouldnt be a bad upgrade then since he is down there if money permits then he wouldnt have to do so down the road if he went with b-series etc. </TD></TR></TABLE>true, cant go wrong with new axles. if you buy the NAPA "new" not reman, they have a lifetime warranty. ive already replaced one of mine because the boot tore
spunautosports
10
Oct 28, 2006 10:08 AM
