what most likely caused this damage? on a built motor
Old Dec 13, 2005 | 04:38 PM
alexsracing's Avatar
Default what most likely caused this damage? on a built motor
a d16z6 turbo and nitrous
could it be the timing or the nitrous, happened on a cold day 50 degrees out
Modified by alexsracing at 10:08 AM 12/14/2005
Old Dec 13, 2005 | 04:59 PM
Fkned's Avatar
Well it looks like it detonated,cracked the sleeve and the head gasket blew after the cracked sleeve.
Old Dec 13, 2005 | 06:00 PM
nsxmatt's Avatar
Default Re: what most likely caused this damage? on a built motor (alexsracing)
I like your sleeves..
But really, 50 shot, stock sleeves, leaner conditions, detonation.
Old Dec 13, 2005 | 06:38 PM
speedworks's Avatar
Default Re: what most likely caused this damage? on a built motor (nsxmatt)
detonation sir.
Old Dec 13, 2005 | 06:41 PM
turboeg77's Avatar
Default Re: what most likely caused this damage? on a built motor (speedworks)
are those SRP pistons? how much whp are you making? def. detonated the *** of your engine
Old Dec 13, 2005 | 08:47 PM
boostedh22a's Avatar
Default Re: what most likely caused this damage? on a built motor (turboeg77)
detonation!!!!!!
Old Dec 13, 2005 | 09:12 PM
1700anddroping's Avatar
Default Re: what most likely caused this damage? on a built motor (boostedh22a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedh22a &raquo;</TD></TR><TR><TD CLASS="quote">detonation!!!!!!</TD></TR></TABLE>
an engine's worst nightmare...sorry it had to happen to you.
Old Dec 14, 2005 | 12:09 AM
714phil's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt &raquo;</TD></TR><TR><TD CLASS="quote">
I like your sleeves.. </TD></TR></TABLE>
haha
Old Dec 14, 2005 | 12:21 AM
RedZone's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboeg77 &raquo;</TD></TR><TR><TD CLASS="quote">are those SRP pistons? how much whp are you making? def. detonated the *** of your engine </TD></TR></TABLE>
Look like CP pistons...I have a customer that has 2 sets that look like this...but not as bad, block was still good and head was fine
Old Dec 14, 2005 | 04:35 AM
seen4ever's Avatar
Default Re: what most likely caused this damage? on a built motor (RedZone)
were the sleeves line bored after the block guard was installed? seems odd you cracked a sleeve with only a 50 shot. still shows alot of signs of detonation, but with that kind of damange it would have to be a nasty explosion. How much did you overbore? what engine management.
Old Dec 14, 2005 | 08:17 AM
nsxmatt's Avatar
Default Re: what most likely caused this damage? on a built motor (seen4ever)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by seen4ever &raquo;</TD></TR><TR><TD CLASS="quote">were the sleeves line bored after the block guard was installed? seems odd you cracked a sleeve with only a 50 shot. still shows alot of signs of detonation, but with that kind of damange it would have to be a nasty explosion. How much did you overbore? what engine management.</TD></TR></TABLE>
It was boosted and 50 shot though with more than likely alot of timing. My fav
Old Dec 14, 2005 | 08:45 AM
y8-turbo's Avatar
boooooooom shakalaka !! holly detonation batman!!
Old Dec 14, 2005 | 08:50 AM
Luchini's Avatar
Default Re: (y8-turbo)
Was it tuned at all?
Old Dec 14, 2005 | 09:02 AM
m R g S r's Avatar
when it was tuned how hot was it?
could have been cold enough and leaned it out just enough so that when you sprayed it blew....
Old Dec 14, 2005 | 09:03 AM
Syner-G-Racing LLC's Avatar
Default Re: (Luchini)
i didnt see anything about a 50 shot...I did see him mention it was 50 (degrees) out (side). He was probaly running 150 shot, if you look in his sig he claims to run 12's...if thats the case...probaly had a little to much timing, but definately detonation cracked the sleeve and took a bite out of that piston.
Old Dec 14, 2005 | 09:08 AM
cp pistons, 75 shot on 16 psi , 18 degrees total timming
Old Dec 14, 2005 | 09:13 AM
Default Re: (alexsracing)
was it tunned? if it was with what?
Old Dec 14, 2005 | 09:23 AM
Zer0DazE's Avatar
looks like a bunch of highway pulls were made 1 after another... the edges on the exhust side got stupid hot and boom.
Old Dec 14, 2005 | 09:28 AM
SOHC_MShue's Avatar
Default Re: what most likely caused this damage? on a built motor (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">when it was tuned how hot was it?
could have been cold enough and leaned it out just enough so that when you sprayed it blew....</TD></TR></TABLE>
Temp correction should have taken care of that. It could have been slightly off with large injectors, but if it was tune conservative enough then i doubt it would have thrown the tune that far off unless he has insanely large injectors.
Old Dec 14, 2005 | 10:04 AM
f22b2tdave's Avatar
Default Re: what most likely caused this damage? on a built motor (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">Temp correction should have taken care of that. It could have been slightly off with large injectors, but if it was tune conservative enough then i doubt it would have thrown the tune that far off unless he has insanely large injectors. </TD></TR></TABLE>
some of us dont have temp correction
pendejon's Avatar
Default Re: (Zer0DazE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zer0DazE &raquo;</TD></TR><TR><TD CLASS="quote">looks like a bunch of highway pulls were made 1 after another... the edges on the exhust side got stupid hot and boom.</TD></TR></TABLE>
also, block guards do a really good job of concentrating heat at the top of the cylinder walls (where they cracked by looking at the pic) and restricting coolant flow. i could definitely see how a bit of detonation could crack the sleeves in conditions like that.
next time, try posting the block (see http://www.theoldone.com), or open deck. Andrea's car made over 600whp on the stock sleeves, but it was b-series.
https://honda-tech.com/zerothread?id=1355442
sorry to see that ****. hope you get the car running again soon.
Old Dec 14, 2005 | 11:18 AM
dsm 450 injectors, uberdata tune for boost only.
happened on the 2nd pass at the track
Old Dec 14, 2005 | 11:26 AM
Fkned's Avatar
Default Re: (pendejon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pendejon &raquo;</TD></TR><TR><TD CLASS="quote">also, block guards do a really good job of concentrating heat at the top of the cylinder walls (where they cracked by looking at the pic) and restricting coolant flow. i could definitely see how a bit of detonation could crack the sleeves in conditions like that.</TD></TR></TABLE>First off block guards do not concentrate heat anymore then a closed deck steel sleeve.2nd detonation occurs when the piston isn't at the top of the bore and it usually cracks the sleeve down in the bore not the top. 3rd posting while it had it's uses will not keep the sleeve from cracking in the same conditions as this one cracked.
Old Dec 14, 2005 | 11:53 AM
coneheadsracing's Avatar
So when you say tuned for boost only, as in not for the nitrous use?? Were you spraying the nitrous the whole time, or just to spool it up. Nitrous would def. cause it to go lean and detonate.
Old Dec 14, 2005 | 01:10 PM
B18 CYA's Avatar
man my cp pistons in my b-series look exactly the same after too much timing...
