lsvtec
if i were to build an lsvtec, and i did it somthing like this
ls block
eagle H beam rods
oversize ITR pistons
B16head w/ IM
ITR cams
I/H/E
ARP hardware
balance roatating assembly
would this perform good all around and make good power for drag race/ daily use? this seems the cheapest and most realiable way to do it if i am not mistaken. since, i want to buy a rolling chassis and do a LS/vtec ....i did search ALOT of search still a little curious
ls block
eagle H beam rods
B16head w/ IM
ITR cams
I/H/E
ARP hardware
not to state the obvious but if you have oversize itr pistons then make sure the block is bored over for the correct size piston. Also there are about a million thread on this topic so try the search option and you will find everything you need. But yeah..sounds like a nice mild set-up
98itr0448
Oct 2, 2004 05:17 PM
compwc18
10
Mar 2, 2004 08:15 AM
