Braided steel lines, permanent fix for radiator hoses?
Old Dec 13, 2005 | 03:21 PM
Boostage's Avatar
Default Braided steel lines, permanent fix for radiator hoses?
Over time Radiator hoses get old and crack. and I know that braided lines are rubber hoses wrapped into a braided steel mesh, now since the mesh prevents the rubber from expanding, does this mean they will never crack?
Old Dec 13, 2005 | 03:25 PM
JDMTurboEG6's Avatar
Default Re: Braided steel lines, permanent fix for radiator hoses? (Boostage)
id use silicone hoses like samco rather than the stainless braided
Old Dec 13, 2005 | 10:14 PM
FairlightRacing's Avatar
Default Re: Braided steel lines, permanent fix for radiator hoses? (JDMTurboEG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMTurboEG6 &raquo;</TD></TR><TR><TD CLASS="quote">id use silicone hoses like samco rather than the stainless braided</TD></TR></TABLE>
Is there an actual reason? Or is this just your personal preference and taste?
Old Dec 14, 2005 | 05:30 AM
mmuller's Avatar
Mad Scientist
those braided sleeves have the strong brided ''look'' but are not really all that strong and i highly doubt they will keep the hose from expanding.
Old Dec 14, 2005 | 08:52 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: Braided steel lines, permanent fix for radiator hoses? (mmuller)
Anything can fail, but the braided rubber hoses you are speaking simply provide more of a buffer. I would also go to silicone hoses if you feel you need extra precautions. For the price, the silicone might even be cheaper.
Old Dec 14, 2005 | 10:29 AM
Flashmn's Avatar
Default Re: Braided steel lines, permanent fix for radiator hoses? (shamoo)
Well radiator hoses have a nylon or steel braid inside the rubber. The external rubber has two functions a) Tuning appearance b) It protects the rubber from external damage. The rubber will still rot over time. Only the teflon braided hose works in keeping the PTFE tube from expanding.
Old Dec 14, 2005 | 07:37 PM
Default Re: Braided steel lines, permanent fix for radiator hoses? (FairlightRacing)
silicone hoses dont breakdown like regular rubber hoses and can handle alot more pressure without swelling.
Old Dec 15, 2005 | 11:42 AM
.water's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMTurboEG6 &raquo;</TD></TR><TR><TD CLASS="quote">silicone hoses dont breakdown like regular rubber hoses and can handle alot more pressure without swelling.</TD></TR></TABLE>
thats why they use silicones for *****...rofl
Old Dec 18, 2005 | 09:40 PM
if you look in the new honda tuning theres a car in there i think its the green eg that has fabricated piping instead of hoses
Old Dec 19, 2005 | 04:03 AM
91civicDXdude's Avatar
honestly, how often do radiator hoses crack and break? maybe one time during the life of the car, if more, theres something wrong. Just buy cheap rubber replacements unless you like the bling factor of the other hoses
Old Jun 22, 2006 | 08:59 PM
maluseanjohn516's Avatar
YO where can i get some of those
Old Jun 28, 2006 | 09:03 AM
slow poke's Avatar
The lines can and will still crack after lots of use.
Old Jun 28, 2006 | 10:15 AM
Do you where to GET SOME they look hot and probally work well
E39Boost
Mar 25, 2013 06:32 AM
robbbby
Welding / Fabrication
Dec 4, 2007 09:39 PM
Boostage
10
Dec 13, 2005 05:05 PM
d mafia
Dec 7, 2001 08:23 PM
