NA RSX-S
Old Dec 13, 2005 | 02:37 PM
DFWRSXS's Avatar
Default NA RSX-S
I'm looking for the biggest performance increase with NA engine upgrades. I plan on getting Injen CAI, RS-R Exmag exhaust, and K-pro to start with. After that I'm not sure if I should replace cams & valve springs or the intake manifold first. What would you guys do after I/E/K-Pro? I'm really not interested in a race header, because I want to keep my car street legal. At the most I might go with a hi-flow cat. Any help or suggestions please.
I want to know what you guys would do after I/E/K-Pro?
Old Dec 13, 2005 | 04:49 PM
EP3tune2RULE's Avatar
Default Re: NA RSX-S (DFWRSXS)
get the Toda package
Old Dec 13, 2005 | 06:01 PM
KOREAN's Avatar
Default Re: NA RSX-S (EP3tune2RULE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EP3tune2RULE &raquo;</TD></TR><TR><TD CLASS="quote">get the Toda package</TD></TR></TABLE>
Old Dec 13, 2005 | 06:23 PM
BoBoChan's Avatar
Default Re: NA RSX-S (korean)
http://www.todaracing.com/prod....html
The Engine Kit
<FONT SIZE="80">+</FONT>
The Stroker Kit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Toda the l33t s4uc3 comp4ny &raquo;</TD></TR><TR><TD CLASS="quote">
2005 RSX Type-S Horse Power Torque ft/lbs
Stock 2005 RSX Type-S 181.2 @7600rpm 134.9 @ 6200rpm
+ TODA N2 Engine Kit, Exhaust Manifold, Exhaust System, Injen Cold Air intake, and DC5 Type-R Intake Manifold 230.7 @ 7900rpm 165.6 @ 6200rpm
+ TODA Stroker Kit - 86mm Kit (2107cc) 262.1@ 8500rpm 194.8 @ 5150rpm
TOTAL POWER GAINS AT THE WHEELS 80.9hp 59.9 lbs/ft.
and your set
Old Dec 13, 2005 | 07:30 PM
DFWRSXS's Avatar
Nice... I've had my eye on the Toda kits. What would you install first? Cams/Spings or Intake Manifold?
Old Dec 13, 2005 | 09:41 PM
dude_123's Avatar
go with intrinsic performance cams/spring kit. You wont regret it!
Old Dec 14, 2005 | 06:23 AM
NJslvrtypes's Avatar
Cams, Valve springs and retainter should be installed first. The intake manifold is going to allow your setup to breath better at higher rpm's. Not going to make a big difference with stock cams because they don't require as much air as the high lift Toda's up in the rpm range.
Old Dec 14, 2005 | 09:54 AM
6SPD_EK's Avatar
get the DTR header which was just released...
screw toda get a custom built IPS block
Old Dec 14, 2005 | 11:42 AM
DFWRSXS's Avatar
Default Re: NA RSX-S (adirondackR)
Thanks for the help everyone. Could you be more specific about the DTR header and the IPS block... I'm new to imports so I'm still learning all the abbreviations.
Old Dec 15, 2005 | 09:12 AM
DFWRSXS's Avatar
Please explain adirondackR... almost 300HP NA?! Holy @$%#
Old Dec 15, 2005 | 10:44 AM
6SPD_EK's Avatar
IPS website http://www.intrinsicperformance.com/
ron is the founder of IPS... search for his topics recent & archived under his s/n "edo"
block is fully custom...sleeved, bored, stroked, forged internals (rods, pistons) castillo crank...probably cost like $10,000 to build the block &lt;--- not sure tho...IPS does make the best cams on the market...the IPS k2's (make more power than toda, skunk, etc... for a street level cam)
DTR stands for Danny Tran Racing - he makes some of the best custom headers... I believe his company is called sixsigmaracing
must be a member to view (www.k20a.org)
http://www.k20a.org/forum/showthread.php?t=7136
http://www.k20a.org/forum/show...eader
Old Dec 16, 2005 | 12:12 PM
DFWRSXS's Avatar
WoW! Nice Header. This is a racing header right? This means I could not keep my catalytic converter so my car would remain street legal... or am I wrong?!? I want so badly to be wrong!
Old Dec 20, 2005 | 02:59 PM
DFWRSXS's Avatar
Which exhaust systems produce the most HP?
Old Dec 21, 2005 | 10:11 AM
newtothis's Avatar
Default Re: NA RSX-S (BoBoChan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoBoChan &raquo;</TD></TR><TR><TD CLASS="quote">http://www.todaracing.com/prod....html
The Engine Kit
The Stroker Kit
and your set
1) How much did all this run you (just price of parts)?
2) How much was the labor to do this, and if you diy, how much can you expect this to cost (average)?
Good numbers I think for NA.
Old Dec 21, 2005 | 11:04 AM
6SPD_EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DFWRSXS &raquo;</TD></TR><TR><TD CLASS="quote">Which exhaust systems produce the most HP?</TD></TR></TABLE>
one made specifically for your setup will yield best gains...DTR, Burns, Hytech
Old Dec 21, 2005 | 11:39 AM
dsmtensai's Avatar
if you want to get an exhaust that gets good gains, ive heard that exhausts with a straight thru design gives better gains than a lot of the exhausts that arent free flowing
Old Dec 21, 2005 | 11:59 AM
aarontrini85's Avatar
Default Re: NA RSX-S (dsmtensai)
man i need to sell my tc for something with a k20 powerplant we dont get any n/a love
Old Dec 21, 2005 | 02:45 PM
TurboGS-R's Avatar
Default Re: NA RSX-S (aarontrini85)
I think the Header in the Toda package makes it NOT street legal, but it is a very nice kit.
whitedawg
Mar 21, 2008 02:26 PM
mydriftobsession
123
Dec 21, 2007 08:09 AM
r1dreams
Jul 28, 2003 07:47 PM
GQ 05YellowEVO8
May 14, 2003 07:46 PM
edo
13
Apr 29, 2003 03:53 AM
