CONFUSED:::driving/fog lamp installation instructions--HELP!
Just got a pair of driving lamp. I'm planning to put them on tomorrow. I read the instrution, I understand most of it but I have a few question before go at it. ((PIC INSTRUCTION))
help #1). In the instruction, it said that I had to connect my drivinglamps to the high beam. I don't want want to do that. I want a separate system with a separate SWITCH. How do I make this work without having to do this?
help #2) In the instruction, it also stated that I had to connect a few wires to the GROUND..((pic shows alot of ground connection needed)). Where should I connect them to? where in the car, please be specific cause I don't want to mess anything up. Is there holes in the car for ground connections? OR can I connect all the GROUNDS together and link them to the "neg" battery?
thank u
thank u
ground the cables to the chasis. if you have a remote switch for the lights hook it up to a power supply that only comes on when you turn on your lights(i patched into my ashtray lightbecause it only comes on when the lights are on) connect the positive wire to an accessory in your fuse box. good luck!!
Lucky-13
10
Mar 14, 2007 02:45 AM
GSblueRacing
Mar 15, 2002 10:16 PM
