car stalls when cold..... :-( help
car was fine then 2 weeks ago i took it to get the valves adjusted, (car has 15,000 miles on it and the valves are noisy too much racing).... but anyway
after that the car started stalling when cold, im thinking its a coincodence...
but what could be causing this...
there are not CEL codes, except teh 2nd o2sensor (testpipe), i had honda just run a top end cleaner thru the motor, the car idles at 600-800 when warm and doenst stall then....
its only when totally cold in teh morning, i dont normally wait for it to warm up b4 drinving down the road, and when i take it out of gear it stalls.....
Im so frustrated already..
car has stock injectors, vafc, greddy blue box.... all which were in teh car for 3-5 months before.... no problems
we did these 2 things...
reset the ecu, and let it idle for 15min at operating temp to idle learn.
and run a top end cleaner thru the motor, and clean the gunk off the idle screw
car still stalls when totally cold...
TheIntegraGuy
Dec 15, 2004 07:08 PM
