question about heater (already searched)
Old Dec 13, 2005 | 12:02 PM
GroundZer0 336's Avatar
Default question about heater (already searched)
ok so i took my heater and all that junk out a while back. i got it all put back in and just wired the blower motor to a switch so its full blast all the time. ran the hoses back to the heater core and all that stuff. ok its not working. searched on here and found theres a little white lever kind of thing on the core somewhere that can block the air from actually going into the core.
does anyone have a picture of this? or can you just tell me is it the one on the right side bottom of the core that has a cable attatched?
Old Dec 13, 2005 | 12:53 PM
west nile's Avatar
Default Re: question about heater (GroundZer0 336)
no pic, but is not neccessary, it is the white lever on right side of heater core with the cable attached. Make sure it is in the position away from the firewall.
also make sure the valve in the engine bay is open too, it should be pointing towards the firewall as seen here...
https://honda-tech.com/zerothread?id=1285605.
Old Dec 13, 2005 | 01:27 PM
Default Re: question about heater (west nile)
yeh i got it. i bypassed the control valve anyways. the core was just clogged w/ ****.
Old Dec 13, 2005 | 07:18 PM
ok one more question.... i just ran the heater for a little while today to see how it was doing, since i straight wired the fan (didnt hook up to switch yet) i just put the power to a constant 12v and grounded the - in a bolt hole...didnt secure it or anything. well after about ...15 - 30 minutes i guess the ground wire got quite hot.
i know thats not good but idont know if it is because of the shitty ground or do i need larger gauge wire...or did i mess it up haha.
Old Dec 13, 2005 | 10:14 PM
west nile's Avatar
hmm thats weird, that fan can't be running over a couple amps, what gauge wire did you use for ground?
mayfly
Dec 10, 2009 08:01 PM
95si_v-tec
Nov 7, 2007 12:06 PM
crxfornow
Dec 12, 2004 09:55 PM
VTECisSeXY
Sep 28, 2003 04:11 PM
Fatty_1775
Jul 16, 2003 06:59 AM
